1939 LaSalle battery box
Started by Jim Stamper, February 25, 2012, 05:57:45 PM
Jim Stamper
     This is a new battery box I made out of 16 Gauge steel. It is a bit thicker than the original and is one piece instead of three pieces spot welded together ( the joints catch and hold water and rust there) It is pre-fit to my 39.  It looks exactly the same as the original except for the one piece construction. I made two new ones while replacing mine.
                                                              $80 plus postage. dstamp4@comcast.net  603 863 2621   Jim Stamper CLC#13470
HFDJR1959
I realize this is a very old post, but do you still have a spare 16g battery box for a 1939 LaSalle?
CLC Member 30062
1939 LaSalle 2 door coupe
Past Cars
1965 Deville Convertible
1970 Eldorado
1934 Buick
1937 Plymouth
1950 Mercury 2 door
1966 Pontiac LeMans Convertible
1968 Corvette Convertible
1970 Ford F100
1972 Chevelle Convertible
Jim Stamper
    Sorry, I put it in my 1940 LaSalle convertible sedan that came along after the post.
     It isn't too difficult to make one with some tools, mainly a bender. I broke an import rated for 22 gauge metal when I used it with 16 gauge. !8 gauge would be adequate  and easier to bend. Make it out of cardboard first .
                                Jim Stamper#13470
HFDJR1959
Thanks for the reply.  I'm traveling back to PA to see family and will stop by the welding shop I used to work at.  Yes it does look pretty simple.
CLC Member 30062
Past Cars
1970 Eldorado
1934 Buick
1937 Plymouth
1950 Mercury 2 door
1970 Ford F100
