Door sills wanted 37 Fleetwood Model 70 4 dr.
Started by Indian, July 19, 2017, 04:24:54 PM
Indian
Wanted door sills for 37 Fleetwood model 70 4 Dr.
31caddy
If you are talking about sill plates, contact:
Donald Kuehn
81 Graham Ave
North Haledon, NJ 07508
973 904-0270
973 423-1196
doorsillsemail addresses not permitted
He makes sill plates for virtually all makes and models of cars. Excellent quality and reasonable prices. He has made them for me for several different cars, and is the supplier to many parts houses.
R. Rowland CLC #28971
1931 Model 355A Sedan (Recently sold)
1931 Model 355A Fleetwood 4535 Convertible Coupe
2005 Cadillac XLR
Brad Ipsen CLC #737
If the 37 Fleetwood is like the 38 to 40 Fleetwood big series cars Don does not make this type.  They are a fairly narrow brass rib with a flange on the side and chrome plate on them.  Don makes the aluminum one.  They are great and considering what it must take to make them very reasonable.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
I agree with Brad. I have used Dons sills on many cars but the big series Fleetwods certainly did use a different type. As he said they are brass and chrome. I have a set from a 1939 Fleetwood and they are quite substantial.  Whats the chances of them fitting or being made to fit the 37 I wonder.
31caddy
The ones he made for my convertible coupe are brass and I had them chrome plated. I had to send templates as I did not have any originals, and he didn't have any either or patterns. Perhaps he can't make the ones for the '37 in brass due to the rib and flange described. Sorry.
2005 Cadillac XLR
Barry M Wheeler #2189
Cadillac was a premier luxury car. When they changed body styles, they CHANGED them. They wanted the cars to appear new and fresh. Continuing a part from an "old" body shell to a brand new one was something they simply didn't consider.
When a body shell was used for (usually) three years or so, one is correct in thinking that a door sill from a 1954 might fit a 1956 Cadillac of the same series. But not when they completely redesigned a body. Even then, they might change the pattern slightly.
So, there is no way a door sill plate from a 1939 Cadillac 75/90 would fit a 1937 Cadillac 70. But Steve was quite generous to think about offering his spare set to help out.
But then they did keep things "the same" like the 1941 lighter and other control knobs up through the 50s. Maddening isn't it???
Best of luck in your quest.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Quote from: Barry M Wheeler #2189 on July 20, 2017, 07:13:37 PM
Your absolutely right Barry but I was thinking that because the bodies in question are big series Fleetwoods and not Fisher they may have in fact carried things over the years. I know they did it in some other aspects.    Perhaps 'Indian' can give the lengths needed for front and back and I will compare?
