Author Topic: 1956 Cadillac Power Steering Pump Pulley Attaching Nut  (Read 282 times)
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« on: December 09, 2017, 01:21:43 PM »
Hello
I need to rebuild my power steering pump and have the unit out of the car.  I cannot break free the attaching nut on the front of the pulley.  I tried vice grips to hold the two washers behind the locking washer and nut.  Using a 1/2" racket, still could not loosen the nut therefore cannot remove the pulley.  Any ideas how to loosen the nut.  If I apply heat, this might melt the rubber seal but I have a new one as part of the rebuild.  Is heat the answer or am I missing another technique.  Thank you all in advance.
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
Re: 1956 Cadillac Power Steering Pump Pulley Attaching Nut
« Reply #1 on: December 09, 2017, 01:39:05 PM »
I had the same problem
 Hit it with an impact wrench. It will break it loose before the pulley can spin. If you dont have one go to a local shop and slip the kid a couple bucks.
CLC #28373
1970 Coupe DeVille
1955 Series 62
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #2 on: December 09, 2017, 01:40:31 PM »
Mike,
Ive used my air impact wrench with no problem in breaking it loose..!   ;)
Good luck..!
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« Reply #3 on: December 10, 2017, 10:58:30 AM »
Thank you, you guys are great.  Now I thought I was ready to rebuild the pump but how do you remove the "key" from the shaft.  The pulley came right off and it appears the key is the guide for the pulley.
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #4 on: December 10, 2017, 05:59:46 PM »
You need to pry it off from the grove, most of the time you can use a small blade screwdriver to get it off but sometime you need a locking pliers to rock it out.
Good luck...!
J. Gomez
CLC #23082
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« Reply #5 on: December 17, 2017, 10:21:42 AM »
Thanks again all.  I'm almost done.  I have two questions.  1) how do I tighten the pulley attaching nut to 35 - 45 lbs. when the pulley just keeps spinning while I try to tighten the nut?  2) Because I could not get the attaching nut off while the pump was on the car, I had to remove the front pump bracket and remove that with the pump.  Now when I replaced the bracket and the pump, I am getting antifreeze leaking from the lower of the two bolts that hold the bracket to the block.  The bolts are about 4" each with a lock washer and spacer.  Again the leak is coming from the lower of the two.  Thank you in advance.  Mike
Online cadillacmike68
  • Still finishing up this 1968
      CLC Member #15823
  • Name: M Santos
« Reply #6 on: December 18, 2017, 08:26:31 AM »
When you took the pump & bracket off, was it or did it start to leak coolant then? Or, did it only start to leak when you replaced them??
"Cadillac" Mike
Current:
1968 DeVille Convertible
1996 Fleetwood Brougham
2009 STS NorthStar Platinum ed RWD
2011 CTS PRemiun ed Sedan RWD
Past:
2008 CTS Premium ed Sedan AWD
2005 CTS Hi-Feature Sedan RWD
2000 ElDorado ESC Hard Boot Convertible
1995 Fleetwood Brougham
1973 Sedan DeVille
1970 Fleetwood Brougham
1969 DeVille Convertible
« Reply #7 on: December 18, 2017, 09:52:17 AM »
Sounds like the gaskets under the water pump are leaking.  The PS pump bracket is secured in one spot to the water pump, so these gaskets may need to be replaced.
Art Gardner
1955 S60 Fleetwood sedan
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« Reply #8 on: December 18, 2017, 10:46:55 AM »
Really good point was made.  There was no leak before I took it off and no leak after I took it off.  It only started leaking after I put it all back together.  I am thinking I did not make the bolts tight enough.  I looked in the shop manual and it states 25 - 29 lbs.  I will torque them down and see what happens.  Now to figure out how to torque the attaching nut on the pulley to 35 - 45 lbs.  I'm thinking to use another nut to lock the first nut in place if I can not get to 35 lbs.  How does that sound?  Thank you all for your help.  Mike
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #9 on: December 18, 2017, 11:07:03 AM »
Mike,
Not a good idea..!
Over-torquing would not cure the leaking issue, best bet is to replace the gasket seals since the ones already in place may have been compromised.  :(
You can try adding one on the top and bottom (PS different sizes) left side and hope for the best, although a quick and duty way of doing things that could or no fix the leak.  ???
I know is a paint getting the new gaskets in place with a full radiator, but you do not want to short change yourself at a later time.   ;)
Good luck..!
J. Gomez
CLC #23082
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« Reply #10 on: February 14, 2018, 08:25:29 AM »
Well I do need to change all the gaskets on the water pump.  Do I need to put any shellac/compound on the gaskets.  I would like to slide all four gaskets on when the water pump is in place.  I can do this by removing one bolt at a time, slide the gasket than replace the bolt.  Do you think I will have a water tight seal without using anything on the gaskets? Thank you again in advance.  Mike
« Reply #11 on: February 14, 2018, 08:42:19 AM »
Sliding gaskets in behind the water pump flanges will probably not seal.  There will be bits of the old gaskets in place.  The water pump needs to be removed, the old gaskets scraped cleanly off the engine block and off the water pump flanges, and new gaskets applied. I use Permatex gasket sealer on them.  Some mechanics don't use anything.  Some use stuff like CopperGasket.  Those are mostly details.  Key thing is to scrape the surfaces completely clean and install new gaskets. Then torque to specs (makeing sure that the bolt and hole threads are clean).  Do not overtighten.
As for tightening the big nut on the end of the PS pump shaft, that is not too tough.  Put the belt on and adjust the belt to be quite tight.  Then tighten the nut, using the engine resistance to turning to hold the PS pulley in place.  If you need more resistance, have a helper hold the engine from turning with a wrench or by grabbing the fan belt or the fan.  Then readjust the PS pulley to have the proper tension in the belt.
« Last Edit: February 14, 2018, 08:45:00 AM by Art Gardner CLC 23021 »
Art Gardner
Offline limikep
      CLC Member #11110
  • Name: mpisciotta
« Reply #12 on: February 14, 2018, 09:13:50 AM »
Thanks for the quick response.  Great info regarding the p/s bolt.  My error that i did not mention the water pump is off the car and all surfaces are clean.  Will I get a water tight seal using no compound and slipping the gaskets in place.  Sorry for the missing key information.
« Reply #13 on: February 14, 2018, 09:26:35 AM »
You ask 10 mechanics this question and you'll get a variety of answers.  Some will say don't use any gasket compound.  Others will say use something like Permatex #2.  Some will say use RTV silicone (I don't like that option).  Some will say use the CopperCoat spray gasket sealant.  Some will say use a sealant, but only on the side facing the water pump flanges.
Me, if the surfaces on the engine block are really smooth and not nicked up or corroded, I say put the gasket sealant only on the faces of the water pump flanges.  Or, if you want to use dope on both sides, use something like the spray CopperCoat.
Art Gardner
