Author Topic: 74 Eldorado parade boot question:  (Read 462 times)
Offline danjarrett1
  • CADZILLA
  • CLC Member #31119
  • Name: D Jarrett
Re: 74 Eldorado parade boot question:
« Reply #20 on: February 03, 2018, 08:12:41 AM »
You’re probably right, I will likely buy a hard boot because it appears tha is what it had when new. I’ve seen them at OPGI for about $600 or so unpainted. Looks like a soft boot is $250or so but I agree, in either case, Black is the color
1974 Cadillac Eldorado convertible
2007 Cadillac Escalade
1980 Cadillac Seville “Bustleback”
Offline e.mason
  • Name: Eric Mason
« Reply #21 on: February 03, 2018, 08:20:52 AM »
Looked too much like the back of a Rolls Royce/ Bentley/Daimler to me.
Cadillac was going backwards in trying to copy something that was old and outdated.
They were Sevilles you either loved or hated.  I personally loved them.  They were really a bold styling move for Cadillac.  The bustle back was quickly copied by Lincoln and Chrysler.  Yes they looked like RR's of old, but dealers were already installing RR grilles, which I personally did not like.
Eric Mason
Offline 76eldo
      CLC Member #22443
  • Name: Brian Rachlin
« Reply #22 on: February 03, 2018, 08:30:53 AM »
You can generally find decent used ones for about $350-500.  If your car does not have the receiver hardware for the locking pins on the hard boot you will need that kit.  Hydro Electric in Florida has the kits.  If you buy a used one make sure that it has the locking pins and all of the rubber parts on the underside of the boot.
If you are not familiar with what's needed to fit this to your car, let me know and I will post some pics of what I am referring to.
Good Luck,
« Last Edit: February 03, 2018, 08:37:27 AM by 76eldo »
CLC # 22443
I prefer email's not PM's   rachlin@comcast.net
1960 62 Series Convertible with factory Tri Power
1960 Eldorado Seville
1970 DeVille Convertible
1970 Eldorado
1976 Eldorado Convertible
1980 Eldorado Hess & Eisenhardt Convertible
1981 Eldorado Hess & Eisenhardt Convertible
1985 Eldorado ASC Biarritz Convertible
2007 DTS
2017 CT5
Offline andysarcade
  • Name: Andrew Welburn
« Reply #23 on: February 03, 2018, 10:29:47 AM »
On the 71-76 range i've not seen many soft boots, but what i have seen have only been white or black vinyl. I have a white vinyl soft boot with Apollo yellow body, tan interior. I like the white soft boot as it matches what the white roof would have done to split up the color palette betwee interior and body. This is why my parade boot might look good in white :)
1974 Eldorado Convertible
Offline Eldorado James
  • 1971-76 Eldorado/Cadillac Specialist
  • Name: P James
« Reply #24 on: February 06, 2018, 10:13:10 AM »
Hello,
No need to drill any holes! :-o  The Eldorado came with a factory soft boot, it would snap onto the woodgrain quarter pad, and had flat nylon tabs that slid under the stainless molding around the rear of the well opening.  The parade boot was optional....
If you want the original GM vinyl soft boot, I have a few in stock in various colors (including white).  Or you can buy them at most convertible specialist places online.....it's the same dimensions/pattern as any 1971-75 GM full sized convertible (Impala, Caprice, LeSabre, etc).  Trim shops make customized ones if you prefer.
A note on "new" parade boots.  They are NOT reproductions.  "GM authorized" and "reproduction" are not one in the same.  The new boots are lighter in weight and possibly not as strong (less fiberglass or ?), and the parts kits are usable but are not identical to the originals.  In fact the Hydro-L-ectric replacement/conversion part for the quarter trim pad is downright embarrassing...a bare piece of stamped metal.   The original was a shiny stainless steel part.  Bare metal does not suit an Eldorado well, my friends!  LOL....That is why good used originals will always cost more than the aftermarket "replacement".
Regards
James
~Eldorado James~
Currently:
1972 Eldorado Convertible
1975 Eldorado Convertible
Past Cadillacs:  Too many to remember.
