66 Eldorado Autronic Eye
Started by jadob, January 20, 2018, 11:34:10 PM
jadob
Hello. I have a 66 Elsorado with every-option (i believe). In any event the autronic eye in the drivers side front of the engine compartment has a gold color wiring type harness going into the back of the unit and a short green wire that comes out from the back of the unit. The green wire is not connected to anything. Anyone have any idea what that wire is for, and where it should be connected to? Im not good with electronics so im at a loss. Thanks.
JD
Glen
The attached is from the 67 shop manual.  I think the color code is the same but not sure.
Glen Houlton CLC #727
CLCMRC benefactor #104
cadillactim
The green wire is a test wire for the special tester.
Tim
Tim Groves
jadob
Thank you both!!! Tim glad to see ypur still here i have a few other issues i need help with can i contact you directly?
cadillactim
Yes, you can contact me directly. My shop phone is temporarily down due to construction, but you can email me directly at tagroves@wctel.net
Tim
Tim Groves
