where to source a 12v conversion kit for a '47 Cadillac
Started by Justin Norwood, February 02, 2018, 03:36:28 PM
Justin Norwood
I am looking for the best kit for a 6v to 12v conversion for my '47 Series 62 (FYI: I am adding AC). I am okay with going to a 12v ALT; no need to stick with the original looking generator. I was looking at Vintage Auto Garage, and they seem to have a kit for '49-'55 Caddies (http://www.vintageautogarage.com/1949-1955-Cadillac-6-to-12-Volt-Conversion-Kit-p/cad4953k.htm)...but I didn't see a kit for my '47. Any advice on where to source a complete conversion kit is greatly appreciated!
Thanks in advance,
-Justin
1947 Cadillac Series 62 Sedan
Bobby B
Justin,
Hi. Never heard of such a kit.  It's pretty straightforward and not that complicated. A few items have to be addressed. As long as you cover all your bases, you'll be good to go. Maybe have a competent shop do it for you if you're unsure on the details of a conversion. There's so many posts regarding the subject on this forum and on-line. Do some research. Steve Passmore has a great Alternator bracket fabricated that will make your life easier. Use a CS131 Alt and bypass your Regulator internally for a stock look. 6V Starter can stay, you won't cook it, just Spins a little faster, no big deal. >:D Need to address some gauges and change out all your bulbs. Wiring will have less amperage to deal with going 12V.  Enjoy your AC and modern Radio. Good Luck!
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Justin Norwood
Thanks, Bobby. Btw, did you mean a CS121 alternator? (not a CS131)  Just making sure I am not missing anything in my research... There are so many threads on this topic, I may make a 'how to' thread so that a forum admin can 'sticky' it
Bobby B
Quote from: revvies on February 02, 2018, 04:49:47 PM
Sorry, typo. Half right and half wrong.  ::)  CS130 OR CS121 will work.
1971 Datsun 240Z
1979 H-D FLH
Steve Passmore
Sorry Bobby, not enough stock on a CS130 to machine enough off to fit my front bracket.  Only the 121 will work unless one grinds out the front timing cover ears.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Bobby B
Quote from: Steve Passmore on February 03, 2018, 08:22:36 AM
Steve,
OK.. I guess that other 10mm larger makes it a No-Go. CS121 it is  ;)........
1971 Datsun 240Z
1979 H-D FLH
Justin Norwood
For posterity's sake...
In terms of the "12v conversion kit" -- Vintage Auto Garage does not offer it for a '47...mostly because they don't have Steve Passmore's alternator+bracket. That said, they can get you the other parts that you need (e.g. voltage reducer 12V-to-6V for Oil, Gas, Temp Gauge) if you call them. I ended up talking to Jay, the technical guy.
