Author Topic: 66 DeVille quarter script mounting template  (Read 150 times)
Offline Chuck Swanson
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« on: February 11, 2018, 02:43:00 PM »
Anyone have, or maybe can make, a template for the holes for the convertible "DeVille" quarter script for a '66.  Made a mistake a while back and covered the two holes on each side when doing the body work.  Picture of one removed would work, but ideally a trace on a piece of paper, maybe then scanned as a pdf would be great...center molding and send of quarter panel would be a good guide.  Size of holes?  Anyone also know the size pins used to mount?   I believe they are just pressed in, no?  Thanks!  Chuck
66 DeVille Convertible (3)
64 Series 62 (2)
64 2 door
66 Sedan DeVille hardtop
65 Eldorado Bk/Bk
69 DeVille vert
97 DeVille d'Elegance
67 Chevy II Nova (AACA GN 2016)
69 Dodge Coronet R/T
98 American Tradition 40' DP RV
AACA Lifetime
Offline cadillacmike68
  • Still finishing up this 1968
      CLC Member #15823
  • Name: M Santos
Re: 66 DeVille quarter script mounting template
« Reply #1 on: February 13, 2018, 05:41:27 PM »
Do you have the scripts? It's just two pins, center point distance from the two pins is all that you need.
Yes I have them on my car (same script from 1965-70),  but I'm not pulling them off to measure the pin distance.
"Cadillac" Mike
Current:
1968 DeVille Convertible
1996 Fleetwood Brougham
2009 STS NorthStar Platinum ed RWD
2011 CTS PRemiun ed Sedan RWD
Past:
2008 CTS Premium ed Sedan AWD
2005 CTS Hi-Feature Sedan RWD
2000 ElDorado ESC Hard Boot Convertible
1995 Fleetwood Brougham
1973 Sedan DeVille
1970 Fleetwood Brougham
1969 DeVille Convertible
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #2 on: February 13, 2018, 06:42:16 PM »
Yes, have the scripts, but wanted the original distance from back of car to first back mount of emblem vs guestimating :)  I then can of course measure the distance to front hole.  Height above center long moulding would be goo too.  Chuck
64 Series 62 (2)
64 2 door
65 Eldorado Bk/Bk
69 DeVille vert
AACA Lifetime
Offline TC
  • Name: Tom Stephens
« Reply #3 on: February 14, 2018, 10:01:52 PM »
Remove the trunk side cardboard liners. You should be able to see where the holes were filled.
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #4 on: February 14, 2018, 10:34:32 PM »
Thanks for the reply...I wish, but there is a second reinforced metal panel in trunk behind cardboard, so you can't see holes from inside trunk.
64 Series 62 (2)
64 2 door
65 Eldorado Bk/Bk
69 DeVille vert
AACA Lifetime
      CLC Member #15823
  • Name: M Santos
« Reply #5 on: February 16, 2018, 11:25:27 PM »
It's got to be the same from 1965-70, but my passenger side has all the jack stuff and the driver side has two amplifiers so I can get in back. The pins were held by those little speed nuts or trim nuts.
I can measure from the bottom of the script to the top edge pf the molding and from the last "e" to the quarter edge (driver side) on my car if you want.
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
« Reply #6 on: February 17, 2018, 01:19:57 AM »
This is a totally radical idea.  I donít know if it will work but I think it is worth a try.  This assumes the holes were filled with a putty and not welded up.  Using the strongest magnet you have, run it over the area with some padding to protect the paint.  Collect some iron filings from around a grinder or other source.  Then sprinkle the filings on the area where you think the holes are.  If I am right the filings will stick to the car and form circles around the holes.  It might help to magnetize the iron filings too.
Glen Houlton CLC #727
CLCMRC benefactor #104
