Help 48 lovers
Started by H Desser, April 06, 2005, 07:05:31 PM
H Desser
Has anyone had any luck matching the greenish-blue-gray face in the 48 speedometer and if so what colors did you use to color it as it appears it needs to be a clear color (candy color).  The plate under the speedometer that has the light switchs and ignition switch and has the engine turning design on it is also this color.  PLEASE HELP AS CANNOT SEEM TO FIND A MATCH AND OUR CAR IS IN THE DOWNHILL MODE OF RESTORATION AND NEED TO KNOW.  IT CAN BE SEEN IN RESTORATION @ http://www.desserconsulting.com TARGET=_blank>www.desserconsulting.com
THANKS FOR YOUR INPUT     HERMAN
