WTB: 77 Seville pass side headlamp bucket
Started by mechanic80, June 14, 2014, 01:34:23 PM
mechanic80
Need the black plastic housing for the rt h/l assy in decent condition.  All attachments unimportant.
mechanic80
Gene Beaird
Norbert, is the headlamp bucket you have cracked/damaged?  Both of the buckets on our 79 were cracked, and had missing pieces, but I was able to satisfactorily repair them with the application of some two-part epoxy to the cracks, and once that set up, I covered the cracked area with some fiberglass cloth and fiberglass resin one finds in those Bondo type fiberglass repair kits.  I then painted it in a semi-gloss black.  It hides the repairs nicely, and has allowed us to put the piece back into the car.  This car will never be a show car, but the repairs are barely noticeable.
Just a thought, as these things are fragile and are easily cracked in the most minor of bump.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
waterzap
Leesburg, AL
mechanic80
Waterzap: That would be great!  Let me know how to proceed.  I accidentally sent you an empty reply.  There is no "reply" evident on the PM screen.   Of course being computer semi-literate I may not have seen it at all.
mechanic80
