1950 Series 62 ignition Switch
Started by curly, July 08, 2014, 02:07:13 PM
curly
I am in need of a 1950 ignition switch, the entire unit, not just the lock cylinder.  Preferably with a key.
T Lewis
rghobden
I have a1950 ignition switch with two new keys that I would let go for $75.  It is completely reconditioned and is good as new.  I was saving it to use on another project but that probably won't happen.  You can email me direct if you want: russell131@centurytel.net.  Russ Hobden CLC #1235.
Russ Hobden, CLC #1235
curly
