My 56 CDV is dripping at the front of the gas tank and the surface of the tank is wet with some drips at the front center. Puzzled as to why. The sender is only a year old from OPGI and I also had a new fuel line put in last year and been good since then. Then the smell of gas started creeping in my garage this week. Is the next step replacing the whole tank? The tank doesn't appear to be that old.
Have you overfilled the tank?
Could you have a vent tube leaking?
If you turn the car around, and place the front higher than the back, does it still leak?
Quote from: The Tassie Devil(le) on November 11, 2017, 06:47:25 PM
Hey, Bruce. I doubt I overfilled the tank...the gas didn't shoot at me while filling and the needle only went to half after I was done. I haven't test that, but I will check tomorrow.
My "new" sender started leaking after quite some time as well and it was the gasket around the mounting. Make sure yours is good, but you'll need to do that after your tank is down a bit. Get your eyes right on that thing first and see if it is juicy or not while the tank is full.
My new sender leaked through the screw threads, A few small rubber washers under the screws solved that problem.
If your sender is not leaking, I have found that in hot weather, since it has an open fuel system, the gas evaporates and fills the garage with fumes. Keep your garage ventilated and don't fill your tank all of the way up. Hope that helps.
There are three places at the front of the tank that could be the culprit of the leaks, the fuel line pickup on the right corner, the drain plug about center bottom and the fuel sender unit assuming of course there are no other holes that were not detected. ???
There should be some tell-tell sign at the tank of any fuel leak if you still have the original painted one.
Good luck..!
Had the same problem with my 56 a month ago. New tank and sending unit. Does not fit up well in my opinion. Seems to be poorly re-manufactured. Make sure the gasket and screws are aligned well. I put a lot of torque on the screws and it stopped leaking. I'm sure I'll have to pull it apart again sometime and try to bend it up to fit better. Sealing the screws sounds like a good idea too!
Got it fixed up. It was the sender. Had to be taken out and a new gasket was put in along with some sealant.
