WANTED! 1981 Eldorado Air Management Valve + Solenoids
Started by www.eldorado-seville.com, June 27, 2008, 12:20:17 PM
Hi,
I´m still working on my friend Tayfun´s 1981 Cadillac Eldorado project.
One of the last projects we have to finish now is the emission control system and we are having a hard time finishing this, as we just can´t find the Airmanagement Valve Solenoids anywhere. One of them seems to be defective as it causes the ECM to burn through every time its connected. We have toasted about 6 ECM´s before we found the problem.
Does anybody have this valve including the solenoids, or the solenoids laying around somewhere or know a source for good used ones?
You can see some pictures of the valve and solenoids and the Pimperado itself here:
http://www.eldorado-seville.com/tayfun/news/files/solenoid.php
Any help is highly appreciated!
thanks,
Gerald Loidl
Gerald Loidl
1958 Cadillac Eldorado Seville
1966 Cadillac Coupe deVille
1967 Cadillac DeVille
1967 Cadillac Fleetwood Eldorado
1974 Cadillac Coupe deVille
1978 Cadillac Eldorado Biarritz
http://www.cadillac-bigmeet.com
Tonyv_73
Any update on this? I have the same issue, unplugged the solenoid and it didn’t fry my computer but car won’t start
1963 Series 62 Convertible
1965 Eldorado
1966 Calais Sedan
1970 Fleetwood Brougham
1970 Wildcat
1970 Coupe Deville
1973 Eldorado Convertible
1974 Coupe Deville
1976 Coupe Deville
1981 Eldorado Biarritz
1985 Eldorado Commemorative Edition
1991 Brougham
1993 Eldorado 4.9
1996 Fleetwood Brougham
2006 XLR
2006 DTS
2014 XTS
Hmmm, a thread from 2008.........
6 ecu's?  Who was it that said something about doing the exact same thing over and over again and expecting a different result?
Unplugging the diverter valve should not keep the engine from starting or running.  All that valve does is direct the AIR (smog pump) flow to different places depending on conditions to improve emissions.  Its all on the exhaust side of things so doesn't directly effect the engine running.   Ya it could effect the reading the computer sees on the O2 sensor and if it was not connected could cause the computer to go into some sort of a limp mode which could effect performance, emissions, and economy but really should not keep the engine from running.
Eric DeVirgilis CLC# 8621
Engine shown isn't the stock motor for the car so there is nothing useful to be learned here.
Wow - this is an old thread...
Just as a folllow up. We replaced the valve and the ECMs no longer were fried...
@Eric - this is the stock motor. Everything was plated though.
@Tj - the engine ran without this valve but itwould run in emergency mode.
Anyways - very old thread. My friend sold the car a couple of years ago...
Gerald Loidl
Quote from: www.eldorado-seville.com on October 15, 2019, 02:26:14 AM
What engine is that? Was it modified?  A V8-6-4 would have had tower rocker covers with wiring at the top for the valve selectors, it doesn't appear to be a V6 and it's not a diesel. Those were the three engines available in an '81 Eldorado.
wrench
I went to the website and checked out one of the videos. Very high production value in the video and very impressive shop work technique. White coveralls and white cotton gloves on the interior. Very clean shop space.
Nice car. I like the ‘58.
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
Quote from: Eric DeVirgilis CLC# 8621 on October 15, 2019, 08:18:02 AM
Its the original 368, but the variable displacement components were removed and regular valve covers were installed instead. Everything else were stock parts which were chrome and gold plated or polished.
Gerald Loidl
