57 fuel pump
Started by 13814, May 20, 2016, 06:44:04 AM
13814
Will I damage a 57 motor if I use a 58 fuel pump. Every thing looks the same except the position of the inlet & outlets?
Walter Youshock
No.  Should be fine.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
