57 cad anyone know what this
Started by 60eldo, October 14, 2017, 05:33:10 PM
60eldo
   I was pulling off my front brake drums when I took off the dust cap this copper thing fell out and now I dont know whats its for and how does it go back in,,,is it nessesary.
Jon. Kluczynski
Bobby B
Quote from: 60eldo on October 14, 2017, 05:33:10 PM
Static Eliminators......
Yes, they were OEM, but most mechanics took them off the first time they did a bearing job on the front hubs. The purpose of them was to offer a low resistance path to ground for static that is generated by the rubber tires to dissipate to ground. The static charge would eventually dissipate without them once the voltage was high enough jump through the grease in the bearings, but the static collectors were supposed to keep it bled down. The only purpose was to make the AM radio reception better. The same reason all the ground straps, ignition shielding and condensers were installed all over the car. They were trying to stop the "pops and crackles" that are so annoying on AM radios.
                             Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
60eldo
Thanks, I took the nut and cotterpin out cause I was hearing some noise intermittantly, in dr side front wheel, and now I can get the bearing out. Shouldnt it just slide right out?
Jon. Kluczynski
The bearing cone should slide right out, and if it doesn't, something is wrong.   Possible cruddy, dirty grease stuck to the spindle, or wear build-up on the spindle from a spinning inner ring.
Love the way the factory tried every means possible to limit static electricity.
60eldo
    Yes it all started cause when I was driving I heard like metal on metal grind, so I started taking the dr side wheel off but the bearing is stuck, I think its broken in side. So how to get it out any ideas?
Jon. Kluczynski
If it won't come off when simply removing the nut, then the only way to get the hub off will be to use a large slide hammer.
BUT, have you backed off the brake shoes via the adjuster?   It could be that there is a lip in the back of the drum, caused by natural wear of shoe on drum.
60eldo
  Haha wish I had a slide hammer, even better, I wish I knew what a slide hamer was, I will look into this and about the brake shoes thanks
Jon. Kluczynski
Jeepers Creepers
They're ninja stars. ;)
Kevin and Astrid Campbell
Australia
Jon S
If you try to pull the wheel off it should pop out.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
They're ball bearings and not like the modern roller cone setup that slips out.   The brake drum is pressed on the hub, so you have to remove as one piece.   So the brake adjuster needs to be detensioned.   Get a shop manual first.   I can copy the pages, if you need ASAP.
60eldo
   Ok, Im gonna try again this afternoon, So I took the nut and washer off maybe I can tap it from the back with a sledge hammer, I think the bearing is whats holding it on.
Jon. Kluczynski
60eldo
#11
    OK I got the drum off by tapping from the back of the drum. Looks like the reason it would not come off is the outer race bearring was stuck to the shaft. Looks like no damage done maybe I will try rubbing some fine steel wool on the shaft and the inside of the bearring.  Tryed that it still wont go on the shaft unless I force it. Should I try to find another race bearing? And should the outer race bearing slide on and be able to spin freely.  Thanks
Jon. Kluczynski
60eldo
   OK I inspected the bearing and found this. Looks not good, that must have been the grinding noise I heard.
Jon. Kluczynski
Boy, definitely make grinding noises.
Bobby B
Quote from: 60eldo on October 15, 2017, 06:42:06 PM
I would think so...... :o
                     Bobby
1971 Datsun 240Z
1979 H-D FLH
Cadillac Jack 82
Keep those static collectors they are hard to find.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
asavage
While searching for information about "radio static collectors" today, I ran across this thread, and it brought to mind my experience with my '59 Cadillac Eldorado Seville, which I owned in 1980-81.
For many years, Cadillac installed a "radio static collector" spring in the front wheel bearing grease cap.  At some point, this spring was discontinued, but I was sufficiently surprised by seeing one installed that the memory remains more than forty years later.
As shown in the exploded view above, Cadillacs through 1959 used ball bearings on the front wheel hubs.  These had a short service life.  For 1960, Cadillac finally updated to roller bearings.  (and full-flow oil filters, and self-adjusting drum brakes, and . . . )  More friction but also more bearing contact area: higher load rating.
At the time, I believe I was unable to find direct roller bearing replacements that would fit the '59 hubs.  After two ball bearing failures on mine, I upgraded my '59 to a pair of junkyard-sourced 1961 DeVille front hubs :)  Much improved durability.  I sold the car in late 1981, I believe.
