Author Topic: 1957 Eldorado Dual Quad setup (complete)  (Read 156 times)
Offline Rockfish39
      CLC Member #17873
  • Name: Lou Baksa CLC #17873
« on: November 01, 2017, 12:57:49 PM »
1957 Cadillac Eldorado Dual-Quad setup (complete), all of the small hard-to-get and expensive pieces are included. Fully and beautifully restored assembly. Intake casting #1465950, Correct 1957 #2582-S and #2583-S Carter carbs freshly restored by All American Carburetor in Daytona Beach , FL.
The intake manifold has never been welded on or repaired and has been professionally upgraded to keep from boiling modern day gasolines straight out of the carbs on warm sunny days. The engine paint stays fresh looking and stays on the iron, instead of burning right off the metal shortly after startup. Fully equalized expansion coefficients of materials and engineered heat dissipation means a lifetime of beauty and performance with these parts!
Perfect and correct 1957 Cadillac batwing air cleaner with the off-set pots. Paper element air filters. Custom machined and polished stainless air cleaner hold-downs. Completely functional and the carbs are properly tuned for a stock cam equipped 365 CID Cadillac engine.
Ready to bolt on and run or put it on your finest '57 Eldorado showcar.
Functions just as good as it looks. Buy will pay actual shipping costs.
$4,500
« Last Edit: November 10, 2017, 08:04:23 AM by Rockfish39 »
