Author Topic: Drum brake spring diagram 68 SDV  (Read 190 times)
Offline taintedsaint
  • Name: Joe Slater
« on: November 05, 2017, 05:50:12 PM »
Does anyone have a photo of the entire spring/arm/shoe assembly for rear of 68 SDV? I thought I would get by with pics pre-teardown but something ain't looking kosher. All I can find is for 61-64.
THanks in advance.
Joe S>
Nokesville, VA 20181
Online The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Drum brake spring diagram 68 SDV
« Reply #1 on: November 05, 2017, 06:39:07 PM »
Here are a couple of pictures of the rear brakes on a '69 SDV.
The fronts should be the same, except for the parking brake mechanism.
Sorry I don't have a better picture of the brakes looking up from under, showing the adjusting screw part.
Offline cadillacmike68
  • Still finishing up this 1968
      CLC Member #15823
  • Name: M Santos
« Reply #2 on: November 05, 2017, 08:17:21 PM »
Shop manual???
"Cadillac" Mike
Current:
1968 DeVille Convertible
1996 Fleetwood Brougham
2009 STS NorthStar Platinum ed RWD
2011 CTS PRemiun ed Sedan RWD
Past:
2008 CTS Premium ed Sedan AWD
2005 CTS Hi-Feature Sedan RWD
2000 ElDorado ESC Hard Boot Convertible
1995 Fleetwood Brougham
1973 Sedan DeVille
1970 Fleetwood Brougham
1969 DeVille Convertible
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
« Reply #3 on: November 06, 2017, 12:02:53 AM »
From the 68 shop manual
Glen Houlton CLC #727
CLCMRC benefactor #104
Offline TJ Hopland
« Reply #4 on: November 06, 2017, 12:08:26 AM »
What do the stabilizer plates do on the front?   I have never seen a setup like that.
Also annoying they don't show the parking brake arm in that photo.   Hopefully its in another one.  If you have not done a bunch of em it can be hard to figure out how it all goes together.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
  • Administrator
      CLC Member #18992
« Reply #5 on: November 06, 2017, 12:38:56 AM »
The Parking brake arm is there.   Just behind the rear shoe, connected to the top link.   You just can't see where it attaches to the parking brake cable.
      CLC Member #15823
  • Name: M Santos
« Reply #6 on: November 06, 2017, 06:49:29 AM »
Joe, are you trying to re-shoe your brakes? Are they assembled now? What I do (because I don't do this often) is I take both wheels off, take one side apart and use the other side as a guide to getting everything back together correctly.
If you have drum fronts and want to convert to disc, PM me. I have the steering knuckles, arms, backing plates and rotors.
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
Offline tripwire
      CLC Member #30157
  • Name: Wes Paro
« Reply #7 on: November 06, 2017, 11:33:44 AM »
Joe,
Just in case you're not aware, the image from the service manual is showing the right / passenger side and the left / driver side will be a mirror image of the right side.  Not the same as the right and also take note the brake shoes.  There is a primary & secondary shoe.  The shorter one is the primary and goes to the front.  It may also be of different material or color to help id it.  Sorry if I'm restating the obvious and you knew all this before I chimed in.
WParo in VT
Driving now:
2013 CTS4 Performance Coupe
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
  • Name: Joe Slater
« Reply #8 on: November 07, 2017, 12:34:28 PM »
Thanks so much to everyone for their replies!!!! The image posted in the reply is exactly what I needed. I had planned to do what cadillacmike said, remove one side at a time. However an overly zealous assistant (son) decided to help breakdown drivers side while I was cleaning up passenger side for re-assembly. The weird long bent rod at top that runs along bottom of green spring had me confused as to hooking from top down or bottom up. Diagram solved the problem.
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #9 on: November 07, 2017, 01:53:29 PM »
At least your son is working on it with you-----that is a WIN!
CLC #28373
1970 Coupe DeVille
1955 Series 62
