Author Topic: Inline thermostat  (Read 314 times)
Offline tturley
      CLC Member #28929
  • Name: Tom Turley
Inline thermostat
« on: November 06, 2017, 10:22:04 PM »
Has anyone ever used an inline thermostat on a flathead when they have disabled the shutter system?
If so what did you use and on which hos.
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Offline Steve Passmore
  • Name: Steve Passmore
Re: Inline thermostat
« Reply #1 on: November 07, 2017, 02:57:54 AM »
If you could find something to use in line, you would have to fit one to both hoses.  Can't say I have ever seen a thermostat made to fit inside those small hoses.
Thermostats have to fit into a housing. I suppose you could bolt two housings together on each hose but that would look crap and would have no by-pass hose for cold starting.  Later cars used a by-pass hose from the pump to the left-hand head.
http://www.jegs.com/i/JEGS-Performance-Products/555/53270/10002/-1
Offline Hilarius
      CLC Member #26898
  • Name: Hilmar Schneider
« Reply #2 on: November 07, 2017, 04:44:09 AM »
Over here in Germany, many such inline thermostats are still available. Even with the bypass connection for cold starting:
https://www.ebay.de/itm/Thermostat-Thermostatei-Kuhlwasserregelung-DDR-Oldtimer/362144193463?hash=item545179dbb7:g:J-sAAOSw09xZ9jA2
Hilmar Schneider #26898
1930-162, "353", 4D-SDN-7P
1939-6127, 2D-CPE-2/4P
1940-7567, 2D-CCP-2/4P
1948-7519X, 4D-SDN-5P
1952-6019X, 4D-SDN-5P
1973 Mercedes 107R, 2D-CCP-2P
2015 Cadillac SRX, 4D-SDN-5P
« Reply #3 on: November 07, 2017, 05:17:04 AM »
That's an interesting little thing Hilmar. My translation says 'Used' Also, it seems ridiculously cheap if it has a thermostat built inside the unit as that's cheaper than a bare thermostat.  Are they readily available new?
Found these in the US without the by-pass but never seen one for sale here.
https://www.ebay.com/itm/JEGS-Performance-Products-53260K-In-Line-Thermostat-Housing-Kit-Includes-/311419312323
Offline gary griffin
  • garygriffin@Q.com
      CLC Member #26430
  • Name: Gary Griffin
« Reply #4 on: November 07, 2017, 11:03:26 AM »
In 1960 I was stationed in Germany  I owned a 1950 Mercedes 220 model (as I recall) and it had manual dampers instead of thermostatic again as I recall? It also had a central foot pump activated lubrication system. Machinery was so precise that they used 30 Weight oil instead of the grease we use again "As I recall"  It was a very nice 6 cylinder overhead cam car while most of the Mercedes on the road were 4 cylinder 180 and used diesel as I recall.   I have always loved cars and Frauleins but Frauleins  won back then "as I recall".
« Last Edit: November 07, 2017, 11:54:21 AM by gary griffin »
Gary Griffin
1942 Cadillac 6719 (parts car) (Gone)
Offline Hilarius
      CLC Member #26898
« Reply #6 on: November 07, 2017, 01:18:00 PM »
That's more like the price I would expect Hilmar.
