1960 transmission clunk noise
Started by 60kaddydaddy, November 23, 2017, 10:22:34 AM
60kaddydaddy
Transmission making clunking noise when shifting from reverse to drive.Could it be the u joints?
Sure.
Could also be a bad center carrier bearing, loose exhaust, bad trans mount or bad engine mounts.
Lots of stuff to check.
How high is the idle on the car?
gkhashem
I have had the same issue lately. I was also thinking my idle was too high after the car was warmed up.
So I finally got off my butt and cleaned the carb and linkage and noticed the fast idle cam was not rotating to knock it off fast idle.
I cleaned it up a bit and guess what 99% of the clunk is gone.
So try the simple stuff first and check the idle.
Wonder if I need to adjust the fast idle screw, I will notice how she idles from cold next time.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
