WTB 66 Eldorado Twilight Sentinel Control Sensor with wiring and connector.
Started by jadob, February 20, 2018, 04:32:26 PM
jadob
Hello. My Eldorado is missimg the sensor that goes umder the dash for my twilight sentinel. All other parts are there and the wiring to commect the sensor is under dash also pic included. NOS or working used part.
Thanks.
J. Dobine
Jeffrey Burland
So you need the photocell itself. Seems these are calibrated with the amp unit under the dash. Not sure how that's done, or the resistance parameters of the photocell for a generic replacement.  GM #910796, 65-66 only (except 65 series 75). I may have one around and will contact you directly. Thanks, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
jadob
Thank you Jeff. I purchased a rebuilt unit for under the dash from Tim Groves, but later realized that i was missing the photocell. When i pulled the dash cover i found no photocell and the connector in the pic just dangling without anything attached to it. Im asuming thats where the photocell cell connector would connect to. Any help would greatly be appreciated.
J. Dobine
