57/58 Brougham hubcaps
Started by Bob Hoffmann CLC#96, April 14, 2005, 10:53:10 PM
Bob Hoffmann CLC#96
 Is there any difference between 57 & 58 hubcaps? If so,how do you tell them apart? Thanks, bob
Roger A. Zimmermann # 21015
According to the Brougham parts book, the hubcap is the same for 57 & 58, as well as the medallion. The hubcap is specific to the Brougham, the medallion is identical to 1957 Cadillac models.
Roger
Pat
Bob - Are there any member numbers ahead of yours or are you one of the original founding fathers?
Pat
Bob Hoffmann CLC# 96
Hi Pat, thanks for asking. There are a number of people that joined the club before me. I joined in the early 60s. I am a charter member of the Northern California region. I wish I was one of the founding fathers. Regards, Bob
Bob Hoffmann CLC#96
Barry Wheeler #2189
One year , the Club decided to assign #s as members renewed. I renewed late so I got a relatively high 2189, but I had been a member since 1964. (And still am not one of the founding fathers. I think BCA assigned #s at the start, so their numbers do reflect longevity in the Club. Their # 2 had the 41 convertible sedan in the movie Pearl Harbor.
Michael / Denmark CLC#21905
Hi,just wanted to now if some could answer this:On some early fab.pictures the Broughams have Sabre spokes on,where they discharged for the prod. model??
The pictures you are speaking about are prototypes. The regular Brougham have another wheel construction, more complicated than the sabre wheels: the rim is steel, the wheel is chromed aluminum, there is a hub riveted to the wheel and made of chromed pot metal. On top, there is the hubcap and medallion...
Roger
Yann Saunders, CLC#12588
I have pictures of a number of Broughams with the cast alloy, so-called sabre-spoke wheels of the regular Eldorados built from 1956-1958. Whether or not these were factory-installed is debatable but I guess a buyer COULD order his Brougham with the sabre wheels in lieu of the turbine-blades.
