1940 LaSalle Tightening torque
Started by Hans Ackermann, March 10, 2014, 03:37:04 PM
Hans Ackermann
I'm stuck on my project and I was wondering if someone knew what the tightening torque is for the nut that keeps the bearing in place at the rear axel.
Thanks in advance. Hans Ackermann
1940 LaSalle Ser.50 Model 5011 2-door Sedan
1918 Ford Model T Touring
1950 Rex Villiers Road Master
1977 Honda CB750 F
Warren Rauch #4286
  You probably are not going to find the spec. Cadillac for many years did not permit its Service Stations to service rear axles. They required them to remove the carrier (nose) and return it to factory for service. Are you looking for nut on the pinion shaft or the side carrier bearing?
   There is a spec for the pinion nut for 1941-52 except series 75 and CC.  These used a 7/8 " shaft (225ft/lb). I believe your shaft is 1/2" , the same as the 75/CC above. Don't try anything near 225! In the shop manuals they give instructions on replacing the pinion seal,of this period. They tell you to measure the torque it takes to turn the carrier BEFORE you remove the nut , and then tighten it to return that  torque (drag).Warren
Hans Ackermann
It ist the nut 1-5/8'' out side off the brake drum.
Sorry for my bad explanation...
1977 Honda CB750 F
Steve Passmore
I don't think there is a setting for the drum nuts, I stand on a 2 foot bar till it won't move anymore.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
harry s
The 1948 shop 'manual gives a torque tightness of 285 to 315 ft lbs on a 1" 14 thread size. That should be about the equivalent of standing on the two foot pipe.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Hans Ackermann
Tank's for all the good help !!  I am very grateful.
/ Hans Ackermann ( Sweden.)
1977 Honda CB750 F
