Where can I locate the Air Condition Fuse : Cadillac 1964
Started by Cadillac1955, April 01, 2011, 04:29:51 PM
Cadillac1955
I wonder where can I locate the 25 Amp Air Condition fuse on a Cadillac 1964?? Located on the fusepanel ?? Please, see attaced pic...
Any, Please........
Andrè Aga
Cadillac Coupe de Ville 1955
Cadillac Coupe de Ville 1964 "The Apollo"
Cadillac Conv. 1965
Jim Sparrow
If you are asking where to buy a replacement 25 amp fuse your local auto parts store should have them. If your 64 is like my 67 the fuse block is located under the dash to the left of your steering column. My 67 also has an in-line 30 amp fuse near the alternator for the high speed (only) of the blower motor. Your 64 might be the same. Hope that helps you.    -Jim
Any Auto Parts Supplier, as these fuses are available in a number of sizes from increments of 5 amp up to 30 amp, and probably more, but with one difference in that there is a 7.5 amp fuse, which is mainly for radios.
But, never seen any 9 or 14 amp fuses.
Cadillac1955
I wonder if the Air Condition fuse or circuit breaker is located on the FusePanel, or located on any wire from the ignition switch....?? I just cant locate the fuse any places under the dash....
Thank You
Andrè
Andrè Aga
Cadillac Conv. 1965
