where does this metal line go?
Started by mr41cadillac, January 24, 2014, 05:37:51 PM
mr41cadillac
facing front of 346 engine there a fitting under the fuel pump about 9 inches down. where does this line go ? cant belive I cant remember but don't see wher thanks john
las39
Vacuum to manifold or to metal tube in firewall grommet for wipers
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
Bill Ingler #7799
Here are two pictures to add to what Mo said.   Bill
mr41cadillac
sorry if i was not clear,the fitting comes off the block about 9 inches down from the fuel pump
las39
Sounds like the valve block feeder that goes under manifold between the two valve covers
1939 LaSalle 5027
1934 Oldsmobile F34
las39
Quote from: Bill Ingler #7799
/quote]
You have a gorgeous engine room :)
1939 LaSalle 5027
1934 Oldsmobile F34
mr41cadillac
thanks it was the valve block feeder line.
