FS 65 66 (?) clock and headlight switch assembly
Started by Glen, November 18, 2014, 02:53:12 AM
IIRC I removed these from a junkyard car in the early 70s.  They have been on my shelf since.  They are not pristine as you can see.  I did not clean them up as I figured the buyer might want to use his own methods.
The headlight switch assembly has the controls for Twilight Sentinel and Guide-Matic.  I did not do any electrical checks on the switch or controls.
I put power to the clock but it did not wind and it did not run.   If it is already wound the oil is probably too thick got it to run.  I sure it ran when put on the shelf.
Asking $40 plus $12.95 for flat rate postage in the US.
Best to contact me by email
tudor_47
Glen,
clock has arrived and I have dismantled it, oiled it and mounted it into my bezel.
Now it looks brand new and yes!  it works!
it will now rest rolled up into a towel, waiting for spring.
I attach a picture for you.
Thanks!
Thank you for the picture.
It looks good.  I’m glad you have it and have it working.
