346 water in the oil and cylinders??
Started by gary griffin, October 14, 2017, 12:02:31 PM
gary griffin
Due to the stripped helicoils I mentioned here in an earlier post I ended up with a little water in one of my cylinders. I pulled the heads and cleaned and lubricated the cylinders with oil soaked wipes. The engine ran after rebuild but has also sat a long time.  There was no water in the oil as far as I could tell. I have still replaced the oil to be sure.
Now it cranks but not fast enough to start or move the needle on the gauge. Starter rebuilt earlier by well known Seattle shop. I am afraid it is too dry now?
I am considering removing the spark plugs and squirting oil in to the cylinders and cranking it without spark plugs until gas gets into the fuel pump and carburetor and oil pressure shows up on the gauge. When it is cranking freely the oil pump would be most active. I see no pressure on the gauge at the slow cranking rate.
Any opinions??
Gary Griffin
Jeff Rosansky CLC #28373
 I am not an engine expert by any means. However that is exactly what I would do. No compression so it should spin fast enough to get oil pressure up.
I did that a few times on the 331 and even got oil up around the valves.
I wouldn't spin the starter over 10 seconds without letting it cool down in between.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Bobby B
Gary,
  If you're still wrestling with this, give me a call. You have my number....
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
