Window problems
Started by robailey, February 17, 2009, 11:51:25 PM
robailey
The windows are working on my 87 Fleetwood Sixty Special, but the are very slow.  Anyone have any idea's what that could be?
Rob Ailey
Seymour, TN
1975 Coupe Deville
1987 Fleetwood Sixty Special
2014 XTS
Ohio57-62Sedan
Throughout the year's I have found that the grease in the window motor will get into the armachure.. What I have found out it is best to us a window motor from a mid 80's 2 door full size car.. The armachure has less winding so it will turn faster.. If replacing them is not an option I would remove the motor take it apart and clean the grease from the armachure.. This is the case with most windows that fail to work....
