Window seals
Started by Denise 20352, August 19, 2005, 02:09:30 PM
Denise 20352
  Where can I get the seals that go along the bottom of the passenger windows, both the outside ones that attach to the door, and the inside ones that are in the interior door panel?  How about the brush-type material that is in the window track?  This is for a 76 CC.
  I may need to buy this stuff by the foot, because I think that the coachmaker made the front doors longer.
thanks
-densie
Porter 21919
Densie,
That would be the beltline weatherstrip, on my 66 CDV they are attached to the SS exterior trim piece, I got them from USA parts and they were made by Steele. They are brass with the rubber molded to them, they have tabs you bend over and you have to use pop rivets on the ends. Some outfits sell lineal footage you have to cut and pop rivet them on.
My interior felts on the door panel were good to go.
Point is Steele is the only manufacturer as far as I know, they have a website. Not as if these items are flying off the shelves at WalMart.
I got a nice custom made vinyl top from Supercar and a few other weatherstrip items, another vendor sent me a bogus vinyl top and it went back for a refund.
Porter ( not 76 advice but HTH )
Rhino 21150
J.C. Whitney has a bunch of weatherstripping in more or less universal styles. Check their website. They are WAY cheaper than Steele. And the stuff (some of it) is sold by the foot. Universal is code for popular Ford and GM, dont bet it will fit your Essex. They have stuff for window channels and once around the door frame or trunk. NOT factory original. No windshield, vent or fixed glass applications.
