1962 Series 62 Missing X Frame Connector In Front of Transmission Pan - Effect?
Started by P. Manoogian, September 01, 2017, 09:22:46 PM
P. Manoogian
This particular car is a convertible. [/size]This is the approximate 40" triangular bar that is just behind the oil pan and is held with 3/8" x 24 bolts (6 - 3 on each side). I have seen these missing before.  They usually are missing after the transmission is R&R'd. The owner of the car (not me) says he doesn't care. Like any part, it's there for a reason. What would be the effect of this missing?
Thank You.
1962 Corvette 327 - 250 HP Automatic Triple Black
1963 Impala SS Convertible - 283 Automatic Black Red Gut White Top
1965 Impala SS Coupe  - 502 Turbo 400 - Crocus Yellow
1974 Corvette L84 4spd Coupe - White / Black Leather
russ austin
Since it is a convertible, I would be trying to talk the customer into having the frame secured together. Twisting of the frame is a concern.
R.Austin
Good question. From the small screws attaching it to the frame, I don't think it can be a good help preventing the twisting of the frame. However, if Cadillac engineers designed the frame with that cross bar, there must be a reason for that. Which one? I just don't know...
dadscad
On my 63, that cross member holds the yaw and sway mounts for the transmission. I also would think it would act as a brace to keep the frame from flexing at the end of the X where it opens out for the front suspension and engine compartment. Like mentioned before, Cadillac put it there, is should be there with the transmission side mounts, if they were used on that model.
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
P. Manoogian
I did put one in, replaced all three mounts and the rear ball joint and spun balanced the tires to "0" inner and out on all 4. No shimmy, no vibrations. Worked out great! Thanks
62 driver
Dave Schneider,  CLC #27889
P. Manoogian
