1957 carbs chokes with trottle,,WHY
Started by 60eldo, April 22, 2017, 09:16:15 AM
60eldo
  I have a 57 cad and its stock. It starts just fine.  The problem is while at idle, if I hit the gas fairly hard it seems to choke out like its not getting enough gas or air, so I dont know where to start looking,,,carb?,,,,vacunm?.....electrical?   thanks for any suggestions
Jon. Kluczynski
Walter Youshock
If it's TRULY stock, it'll have the troublesome choke unloaded where the choke is physically attached to the primary throttle valves.  This was used on olds and cadillac in 1957 and '58.  The idea was that you could start the car and drive off without waiting for the choke to open.  Most were taken off later.
Also, the '57 Rochester is a notorious mess of a carb that requires several adjustments from the shop manual settings.  The Carter is far better.  But, even after all that, mine will still bog a little at takeoff.  It is a typical complaint of '57 s.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
j,
If you let it the car warm up ]then hit the gas to remove the fast idle for the choke does it run ok?
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Glen
Sounds like a bad accelerator pump to me.  That is where I would start.
Glen Houlton CLC #727
CLCMRC benefactor #104
