1976 Series 75 AC Programer
Started by Kevin Bielinski #13320, May 23, 2017, 11:40:51 PM
The AC will not come out of the dash vents unless the programer under the glove compartment's electrical connection is removed. Any suggestions or personal case history to this situation ? I've checked for vacuum leaks so far and all is good. Bot the control head and programer are receiving 17 inches of vacuum each from the manifold.
CLC Western Regions Vice President
1970 Coupe Deville
1973 Miller Meteor 3 Way
1976 Series 75 Sedan
1988 Flower Car
1971 Lincoln Mark III
1984 Lincoln Town Car
1989 Lincoln Town Car Signature Series
2001 Lincoln Krystal Hearse
Past Vehicles
1971 Chevy Impala
1973 Chevy Monte Carlo
1973 Mercury Capri
1986 Lincoln Town Car
1996 Mercury Grand Marquis
1983 Buick LeSabre Limited
cadillactim
With the connector plugged in does the system stay on full heat? If so, check for an unplugged sensor. Can you control the temperature at all? If not, and the sensors are connected very likely a bad programmer.
Tim
Tim Groves
I just had the programer rebuilt by oldair.com. I'll do what you said and see what happens. BTW - Old Air isn't exactly the friendliest group around. They don't return phone calls and most of their answers contain more silence than words
1970 Coupe Deville
1988 Flower Car
Past Vehicles
1971 Chevy Impala
1973 Mercury Capri
