1956 convertible windows
Started by lishka, January 17, 2018, 05:08:53 PM
lishka
driver side window doesn't meet the rear window front edge to low when try to adjust it  the window cracked its to low by a 1\4 to 3]8 inch any ideas. Is the coupe window the same as convertible
Sorry, I don't understand what you try to explain...A picture would be more efficient. I just can tell that convertible door windows are not the same as the ones for a closed coupe.
lishka
thank you for the replay let me try again the rear quarter window front edge is higher then the back edge on my front window bye 1\4 inch when i tried to adjust the front window  up the front window cracked
Then you may have to lower the quarter window; the pivot is adjustable. Compare with the other side and of course, check with the roof rail which is adjustable too, to some extend. As I restored a '56 convertible, I know that it's not easy. Without to know what you did exactly, it's hard to make a diagnostic over Internet.
lishka
thank you again   what is the difference in a coupe window and a convertible one
Quote from: lishka on January 18, 2018, 06:19:26 PM
A different part number. Cannot say more than that.
lishka
