41-47 Wheels 15" x 5 1/2" (need 2)
Started by Paul Phillips, May 13, 2016, 10:14:06 AM
Paul Phillips
Need 2 good wheels 15 x 5 1/2 as used on 1941 Series 61, 62, 63, 60S.  Color not important but condition is.  Please no bent or rusty examples.  Needed to make a complete set to mount bias ply tires for CLC Judging, since my Diamondbacks are now point deductions.
Please send PM if you can help.
Thanks!
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
Bob Schuman
Paul,
I do not have what you need, but this may be helpful. All Cadillac 15 inch wheels for 1941 theough 1947 models are the same. Starting in 1948 they went to 15 x 6 inch wheels which look identical except for the extra 1/2 inch of width. If using the small hubcaps with or without trim rings, the 5-1/2 or 6 inch wheels can be used. If using the large 41-46 wheel discs  the wheels must be the  5-1/2 width, as the wheel discs will not stay on properly with the 6 inch wheels.
Bob Schuman
Bob Schuman, CLC#254
2023 XT5
Paul Phillips
Thanks Bob!  I am using the large wheel covers so 41-47 wheels 15" x 5 1/2" will  be what is needed.  I am changing the listing to match.
Paul
Paul Phillips
Still looking. Someone must have these wheels out there somewhere!
Paul
Mike Wenrich #1666
I have wheels if you are still interested.  Located in Ca.  So depending on your location, not sure what shipping would be.
Private email is mjwenrich@earthlink.net
Paul Phillips
Thanks Mike. I did find the 2 needed but forgot to update this post. Sorry for that.
Paul
