1937 LaSALLE distributor cam removal
Started by 1937 LaSalle coupe, January 09, 2011, 06:41:47 PM
1937 LaSalle coupe
Hello everyone. I was looking at my Delco distributor for my 1937 LaSalle and discovered that the centrifugal advance mechanism is froze up. I took off the 2 weights and springs. On some distributors there is a clip underneath the rotor to remove. Doesn't seem to be a clip on the top of the Delco # 665-G model. I don't want to take the lower gear off if I don't have to. Just wondering if anyone knows how to remove the advance mechanism ? THANKS... John Lehman... CLC #26365...
John,
Once you pull the springs off and remove the advance arms it should just pull up and off. I don't remember any clips holding it one.
Oh, if this is not a show car, and you don't have the original AA25 Stromberg with the electric choke, you might consider installing a 1940 to 1948 distributor with the vacuum advance. Car runs smoother and gets better gas mileage.
Good Luck.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Tom Knoebel
#2
I have just installed a distributor with a vacuum advance on my 39 LaSalle. Where do I hook the vacuum advance up to?
I have the stock carter carb on.
Thanx
Tom
Tom Knoebel
1939 LaSalle 5019, 1940 5019, 1940 5019, 1940 5011
Tom,
If you have a stock 39 Carter carburetor the answer is nowhere.
The vacuum advance piping goes to the port in the base of the carburetor. So you need to get a later base or perchance this one just has a plug in it. If so you can remove the plug.
the johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
