1940 Lasalle 5019 dome light
Started by Ben Medlock, December 20, 2017, 05:10:52 PM
Ben Medlock
Working on wiring for this car and I'm trying to understand the dome lighting.I understand the power comes from the main headlight switch. This wire is always hot so what keeps the light from being on all the time? I understand from my authenticity manual that there is suppose to be a switch on the post between right doors..... can't seem to find that switch...... So I assume this switch that I'm missing breaks the ground making the light go on/off. Assuming my assumption is correct, that means the light housing would have to be insulated from all metal frame contact. I could put a rubber gasket between the light frame and the cab frame but what about each screw.... rubber washer on each??????
Can someone tell me if I'm on the right path of thinking?
Thanks is advance
tturley
There is a switch on the right side B pillar. I will take a pic in a minute and post.
I believe the switch is connect through the cigar lighter and clock and it breaks the power source
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
The switch is not on the ground.  It is on the hot side.  This changed in 41 and after the ground was switched.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
tturley
Dome switch
Member # 28929
1995 Ford F-150
2015 Buick Enclave
tturley
Whoops
Upside down, thought it was going to Australia
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Chris Bryant #19358
Dear Ben,
Please put an inline fuse into the power wire! Joe Ceretti who is no longer a member of CLC lost his 1938 60 Special to a short in the wire to his dome light when it shorted to his right front A-pillar. Cheap and sensible precaution.
Chris Bryant #19358
las39
According to the diagram, feed comes from light switch.
I connected mine so dome is turned on when twisting the knob. Pillar switch is left on position because mine is very brittle.
Originally the terminal turns on glove light, clock light and feeds instrument switch.
Fuse is always a good thing.
Se diagram
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
Ben Medlock
Thanks for the help all.I bought wiring harness from YNZ and the instructions from those guys stated hot wire from main light switch to body plug on dome light. Then they provided another wire stating lamp switch to dome light (ground). That's why i was thinking the ground was to be switched. Anyway, i now have the hot wire going direct to dome light switch with the other wire going from switch to dome light. so, the light housing is grounded to frame and the hot is switched.... what i would call typical.
Now i just have to find a switch.
tturley
The glove compartment light on the 5019 is a mercury switch that activates when door is opened
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
As far as I am concerned the switch that Steve linked to is the correct appearance for these switches.  Cars often have the all plastic switches that you see and people think they are original.  I don't think these are correct.  They were an aftermarket fix at the time for the correct switches that didn't last very long.  One observation that confirmed this in my mine, there were boxes of the plastic ones for sale at Hershey in the 80's.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
las39
Quote from: Brad Ipsen CLC #737 on December 21, 2017, 09:40:12 PM
Interesting. I thought the 1939 had the plastic type switch matching dash and escutcheons, and chrome switch for the 1940 matching chromed dash switches and escutcheons.
1939 LaSalle 5027
1934 Oldsmobile F34
