Author Topic: Power window issues  (Read 101 times)
Offline slowpoke17
      CLC Member #30836
  • Name: John Federico
Power window issues
« on: December 30, 2017, 11:02:39 AM »
Well I've been trying to work on getting my drivers side window back in operable mood but haven't had much luck. I have the service manual and I've searched the forums for instruction but I'm not making much progress. I have the panel off and everything exposed. I did find a pin on the bottom of the door but can't find anything that resembles that in the manual. I can't see where it broke off or came from. Direction is not clear on whether I have to remove the regulator or can this completed with everything in place? The motor works, you can hear it but nothing happens, the window stays in the dropped position. Would appreciate any guidance offered. The car is in winter storage so I'd like to fix it myself if possible otherwise it hits the shop come spring. Here is the part I found:
CURRENT ENJOYMENT:
1988 Coupe DeVille
2001 Corvette convertible
PAST TREASURES:
1965 Calais coupe
1985 Eldorado
1990 Fleetwood sedan
2005 DeVille
2006 DTS
2013 SRX
Offline 35-709
      CLC Member #4719
  • Name: G. Newcombe
Re: Power window issues
« Reply #1 on: December 30, 2017, 12:36:38 PM »
Hard to tell but it looks to me like that arm sticking straight up in the pic. broke off something and maybe it broke flush making it hard to see just where --- if so look harder, you'll find it.  Your cars are newer than what I am more familiar with.
1973 Cadillac Caribou - Sold
1950 Jaguar Mark V Saloon resto-mod
Offline Bobby B
  • Mendham, New Jersey
  • Name: Bob Bender
« Reply #2 on: December 30, 2017, 12:41:39 PM »
John,
     Hi.....
A. What car/ year are you referring to?
B.  It's definitely part of a track/roller assembly. That's the ball part of an arm or assembly that slides with the up/down motion of your window. Where it broke off of and the location of it's mating the socket must be your question...
                               Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Offline slowpoke17
      CLC Member #30836
« Reply #3 on: December 30, 2017, 01:11:25 PM »
John,
     Hi.....
                               Bobby
Hi Bobby,
The car is a 1988 Coupe DeVille. What I'm trying to resolve is what part this broke off of? Its hard to tell with minimal viewing and my minimum knowledge of power windows. As I can't see what is broken I'm trying to decide if I need to drill out the rivets and remove the whole assembly. I knew what to replace I could buy the replacement part and try to do that in place. From what I read its not an easy job to remove and reinstall.
CURRENT ENJOYMENT:
1988 Coupe DeVille
PAST TREASURES:
1965 Calais coupe
1985 Eldorado
2005 DeVille
2006 DTS
2013 SRX
