Author Topic: Well below freezing car and shop tips  (Read 180 times)
Offline TJ Hopland
« on: December 30, 2017, 11:04:48 AM »
Since a lot of us are good and cold even in places that don't normally get cold figured this would be a good topic.
A thing that just got me was I had some hand cleaner and 'purple power' cleaner in the garage that froze solid and cracked the containers.   I brought them to thaw and drain in the utility sinks.   If I had not noticed they would have made quite a mess when they thawed.
Another thing I started doing is keeping one of those weed sprayer bottles that you hand pump up full of the premium washer fluid.   It speeds up the defrosting when spray on glass when its ice covered.   It even helps if your door seals freeze, you just spray it in the cracks.
Anyone have any other tips other than have a heated garage or move south where 'freezing' is maybe 50*F?
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
Re: Well below freezing car and shop tips
« Reply #1 on: December 30, 2017, 11:33:10 AM »
We're in Dallas, low is expected in the low 20s.  The car is garaged and liquids are fine in there.  Cold snap supposed to last maybe 3 to 5 days, then lows return in the mid 30s.
1970 Deville Convertible  MTS 507
Dallas, Texas
Offline 35-709
      CLC Member #4719
  • Name: G. Newcombe
« Reply #2 on: December 30, 2017, 12:30:58 PM »
"Anyone have any other tips other than have a heated garage or move south where 'freezing' is maybe 50*F?"
Nope.  Sounds right on the money to me!   ;D
1973 Cadillac Caribou - Sold
1950 Jaguar Mark V Saloon resto-mod
Offline Bobby B
  • Mendham, New Jersey
  • Name: Bob Bender
« Reply #3 on: December 30, 2017, 12:44:31 PM »
0-12 degrees here in NJ for the last week. It's going to be around for a little while longer. Not worth putting the heat on in the shop....Sucks  >:(
                                                              Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #4 on: December 30, 2017, 02:12:28 PM »
For me it isn't really the cold, it is the salt on the roads. Normally if we get a little snow, it warms up in a few days and then rain washes it away. However it has been dry here and below freezing for the last couple weeks and at least 1 more. I want to go out and drive it..... argh!
CLC #28373
1970 Coupe DeVille
1955 Series 62
Offline bcroe
      CLC Member #14630
« Reply #5 on: December 30, 2017, 03:21:38 PM »
We have been below zero F pretty regularly but things need to
be done.  I use a pair of HOT HANDS pads in mittens to keep
my fingers from freezing while snow blowing and cleaning off
the 250 foot solar array (that supplies my heat).  I have kept
extra pads in the shed in case mine timed out, but today I
found they were not functional.  My guess is, being subject to
some 10 below zero killed them, will need to keep them all
in the house.  Bruce Roe
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #6 on: December 30, 2017, 03:51:40 PM »
Move. ;)
