Author Topic: 1959 Cad drivers side heater hose routing from water pump  (Read 322 times)
Offline John Washburn CLC 1067
  • Call me on my shoe phone 303+885-3545
      CLC Member #1067
« on: January 02, 2018, 04:48:56 PM »
Folks,
Putting a 59 Cad engine together for a 4 door sedan with no AC.
Question is the heater hose, from the water pump, on the drivers side, run under the intake manifold or on top of the intake manifold?
The two hose brackets seem to indicate that the heater hose runs on top of the manifold on the drivers side.
Confused as Always.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1953 Coupe DeVille
1956 Coupe DeVille
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: 1959 Cad drivers side heater hose routing from water pump
« Reply #1 on: January 02, 2018, 04:55:31 PM »
Under the Intake Manifold.
Online Eric DeVirgilis CLC# 8621
      CLC Member #8621
  • Name: Eric DeVirgilis
« Reply #2 on: January 02, 2018, 04:56:02 PM »
Under the intake nearer to the passenger side.
A Cadillac Motorcar is a Possession for Which There is no Acceptable Substitute
Offline gkhashem
      CLC Member #26576
  • Name: George K Hashem
« Reply #3 on: January 02, 2018, 04:56:10 PM »
Both hoses run under the intake manifold. If you want to make it look original overspray some Cadillac Blue from Bill Hirsch on the hoses!  :)
1959 Cadillac Coupe Deville
1964 Oldsmobile 98 Town Sedan
1966 Cadillac Coupe Deville (Senior #861)
1970 GMC C/K 1500
1978 Cadillac Coupe Deville (Senior Crown #959)
1984 Oldsmobile Delta 88 Royal Brougham Coupe
1989 Buick Reatta
1991 Oldsmobile Toronado Trofeo (OCA 1st)
1991 Cadillac Eldorado Biarritz (Senior #838)
      CLC Member #1067
« Reply #4 on: January 02, 2018, 05:03:18 PM »
Now if the hoses run underneath the intake what are the two brackets for? They look like they should hold the hoses in place under the intake? I have two of these but not sure what they are for or where they go...
The Johnny
« Last Edit: January 02, 2018, 05:06:02 PM by John Washburn CLC 1067 »
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline gkhashem
      CLC Member #26576
« Reply #5 on: January 02, 2018, 05:42:37 PM »
What brackets? I do not remember a bracket, do you have a photo of them?
1970 GMC C/K 1500
1989 Buick Reatta
      CLC Member #1067
« Reply #6 on: January 02, 2018, 06:23:11 PM »
I believe that these go on the manifold to support the heater hoses. Not sure but I think they attach to the center bolts of the intake one on each side.
Pictures attached.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline 59-in-pieces
      CLC Member #17326
  • Name: S. Butcher
« Reply #7 on: January 02, 2018, 06:43:59 PM »
John,
A diagram and photo of brackets/clips.
On my cars, the bracket/clips are held down by the valley pan bolts.
Hope they help.
Have fun,
Steve B.
S. Butcher
Offline Caddyholic
  • 1961 Series 62 Convertible 1962 Coupe Deville
      CLC Member #29238
  • Name: Jim Lumma
« Reply #8 on: January 02, 2018, 07:02:50 PM »
They hold the hoses down away from the exhaust crossover so they don't melt. They are held in place by the intake bolt / stud.
I got myself a Cadillac but I can't afford the gasoline (AC/DC Down Payment Blues)
1961 Series 62 Convertible Coupe http://bit.ly/1RCYsVZ
1962 Coupe Deville
      CLC Member #1067
« Reply #9 on: January 02, 2018, 07:49:59 PM »
Thanks all for the help.
Caddyholc thanks for your input I forgot all about the crossover under the carb. But we blocked that off so not sure will use the brackets, but might just because they are supposed to be there.
Steve B thanks for the diagram, not sure the '59 brackets are held down by the valley bolts.
Again thanks all. I am not a '59 guy but am learning.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #10 on: January 02, 2018, 09:33:38 PM »
Just don't hurt yourself on the fins.
CLC #28373
1970 Coupe DeVille
1955 Series 62
Online 76eldo
      CLC Member #22443
  • Name: Brian Rachlin
« Reply #11 on: January 02, 2018, 10:05:19 PM »
I have not seen these on my Tri-Power cars.  Am I missing them?
CLC # 22443
I prefer email's not PM's   rachlin@comcast.net
1960 62 Series Convertible with factory Tri Power
1960 Eldorado Seville
1970 DeVille Convertible
1970 Eldorado
1976 Eldorado Convertible
1980 Eldorado Hess & Eisenhardt Convertible
1981 Eldorado Hess & Eisenhardt Convertible
1985 Eldorado ASC Biarritz Convertible
2007 DTS
2017 CT5
Offline Jeff Wilk
  • J. Wilk CLC # 25630
  • The Past + The Future = My Heaven on Earth
      CLC Member #25630
  • Name: Jeff Wilk
« Reply #12 on: January 02, 2018, 11:32:12 PM »
ive been told that they were std on all 59s but often discarded during engine repair or many actually rusted away from combo of thin metal and engine heat and general corrosion
J Wilk
Central New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Offline INTMD8
« Reply #13 on: January 03, 2018, 07:32:59 PM »
They are on my 59. As Caddyholic mentioned, attached at intake studs, holding the hoses downward.
Jim Moran.   1959 Series 62 Convertible
      CLC Member #1067
« Reply #14 on: January 03, 2018, 07:45:45 PM »
Folks,
I know old Bill the head judge will not agree, but since we have blocked off the crossover we don't need these brackets. We will not throw them away and will keep and provide documents to show what function they were engineered for. Then the next care keeper of the 59 can decide if they want to go back to original.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
      CLC Member #17326
  • Name: S. Butcher
« Reply #15 on: January 04, 2018, 01:30:41 AM »
EVERYONE - MEA Culpa - MEA Culpa
Forgive me for I have sinned - and screwed up big time too.
I consulted a couple of friends for whom I have great respect, and although my 3 Biarritz have those brackets attached to the valley pan - they are not correct.
And since these guys have 20 X +++++ more Cads than me, they both concluded, the mounting is off the manifold, regardless of a single quad or tri-power.
I will hang my head in shame, and not further post until the bleeding stops.
Have fun,
Steve B.
S. Butcher
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #16 on: January 04, 2018, 07:38:31 AM »
I'd be wary to not reinstall them.  Although the crossover is blocked off and burning will no longer be an issue, I'd be worried about vibration and something abrading a hole into one of the hoses.
Dan LeBlanc - CLC # 27657
1977 Continental Town Car
Offline gkhashem
      CLC Member #26576
« Reply #17 on: January 04, 2018, 09:28:54 AM »
Well my memory fails me so I need to look closer at my car.
I removed the original hoses in 2016 and did not take off the intake manifold to install the new hoses. I am going to look to see where the clips are since they must be still present on a very original car.
I will let you guys know where they are but maybe I did not route the hose under the clips I do not remember.
Here are the hoses with blue overspray and all.
Also notice the impression in the hose from the clip. I must have run the new hoses under the clips?
« Last Edit: January 04, 2018, 09:31:56 AM by gkhashem »
1970 GMC C/K 1500
1989 Buick Reatta
Offline David King (kz78hy)
  • Check out the Eldorado Brougham Chapter
      CLC Member #22014
  • Name: David King
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1959 Eldorado Brougham 56
1960 Eldorado Brougham 83
1998 Deville d'Elegance
2003 Deville gifted to daughter
1964 Studebaker Commander
1966 Pontiac GTO convertible
2012 Volt
CLCMRC benefactor 197
Director and Founder, Eldorado Brougham Chapter of the CLC
Past President, Motor City Region of the CLC
Rare Parts brand suspension parts Retailer
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #19 on: January 06, 2018, 10:43:07 AM »
John,
Seems the OE hose was molded and I need one also, so I have been watching this one.
https://www.ebay.com/itm/1959-Cadillac-Control-valve-to-Waterpump-3-4-Molded-Hose-1st-Type/401262880489?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
David
You can get the same hose from NAPA for about $15. I'll see if I can find the gates part numbers for the 3/4" and 5/8" hoses
