Author Topic: Undercoating and sandblasting  (Read 516 times)
Online Paul Tesone
Re: Undercoating and sandblasting
« Reply #20 on: January 07, 2018, 12:02:40 AM »
 Thank you all for the many responses . I'll keep you up-dated . Will post pictures once the cross member is replaced and the body is off the frame . ... Paul Tesone CLC #6876
Offline Quentin Hall
« Reply #21 on: January 07, 2018, 02:38:14 PM »
Hi Paul, Happy new year. Iíve been down this road many times and years of success and failure has made me use several techniques in tandem or unison or altogether....
On body panels putting heat via a torch could destroy or warp a panel pretty fast. The tar is best softened with a thinners , kero, or turpentine. Sometimes you have to trial each to determine the best . Manually scape it .
For external panels I recommend using a caustic solution to remove paint and for rust I use a phosphoric solution. I have a rainwater tank that I can immerse whole doors and fenders and hoods in to gently lift and remove rust with out aggressive blasting.
I always try to do as much preliminary rust and paint removal as possible BEFORE using any abrasive blasting. Abrasive blasting is non discriminatory ie it takes away both debris and substrate so it should be used more to give a key to the metal.
53 Eldo #412.
53 Eldo #433
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
