Author Topic: 1931 V8 Carburetor Removal  (Read 155 times)
Offline Gerald Wagner
      CLC Member #29724
  • Name: Gerald Wagner
« on: January 07, 2018, 05:18:16 PM »
I believe that my float is stuck. What is the best way to remove this updraft carb? Jerry Wagner
Offline Hilarius
      CLC Member #26898
  • Name: Hilmar Schneider
Re: 1931 V8 Carburetor Removal
« Reply #1 on: January 08, 2018, 02:47:38 AM »
After standing unused, the float needle sometimes stick.
Before you dismantle intakes and carb, unscrew the junction in the gas line  between the vacuum pump and the carburetor and, cautiously, blow some compressed air into the pipe to the carb.
This usually unsticks the neddle and gas flows freely, again.
Hilmar.
Hilmar Schneider #26898
1930-162, "353", 4D-SDN-7P
1939-6127, 2D-CPE-2/4P
1940-7567, 2D-CCP-2/4P
1948-7519X, 4D-SDN-5P
1952-6019X, 4D-SDN-5P
1973 Mercedes 107R, 2D-CCP-2P
2015 Cadillac SRX, 4D-SDN-5P
      CLC Member #29724
« Reply #2 on: January 08, 2018, 12:36:40 PM »
Hilmar, Thank you for your note. I have the opposite problem - flooding. Gas seems to pour thru the carb to the ground. I have a new float, needle, and kit. Can the carb be removed without monkeying with the intake manifold? I see in the parts list that two 7/16" bolts hold the carb to the manifolds. Is there a trick to access them? Regards, Jerry Wagner
Offline Steve Passmore
  • Name: Steve Passmore
« Reply #3 on: January 08, 2018, 01:18:46 PM »
We used to just tap them with a wrench when that happened ;D
Offline harvey b
  • The truth is often a bitter pill to swallow
  • Name: Harvey Bowness
« Reply #4 on: January 08, 2018, 01:37:54 PM »
Still do that here too. 8) seems to work about 50% of the time,would definetly try it before removing the carb,
Harvey Bowness
Offline harry s
  • Harry Scott 4195
      CLC Member #4195
« Reply #5 on: January 08, 2018, 03:41:36 PM »
You can remove the carb without removing the manifold. You have to use the braille method though.     Harry
Harry Scott 4195
1937 7529
1941 6733
1948 6267X
Offline Hilarius
      CLC Member #26898
« Reply #6 on: January 09, 2018, 01:43:22 AM »
When your carburetor is flooding, either the float or needle are stuck, or the float still is one of the old ones made of cork which in spite of the sealing laquer has become soaked and too heavy to float, anymore.
Use a new metal one. Check needle and seat, too.
What Harry Scott describes as the Braille method goes like this:
Take the silencer off the carburetor
Disconnect all the rods for choke etc.
Disconnect gas line
Get on a step ladder and lean far into the engine room
Feel your way to the two bolts that hold the carb to the manifold
Unscrew the bolts and take out the carb.
It really isn't too difficult to unscrew the carb and take it off.
Good luck.
Hilmar
Offline Hilarius
      CLC Member #26898
« Reply #7 on: January 09, 2018, 11:08:47 AM »
I forgot to add that you have to take off the "swan neck" that holds the silencer.
The bolts are accessible from the top. If not you have to take off the distributor tower. One of the two has to come out. Too little room, else, as far as I remember.
H.
