Author Topic: 1969 limo hood problem  (Read 145 times)
Offline 1969cadillac
  • Name: murray mules
« on: January 10, 2018, 01:19:13 AM »
hello out there !
the glue ? that seperates the inner and outer metal on my limo hood has fallen apart
Q what is the correct product to use ?
Q I am also thinking of adding dyna mat insulation as well as the factory insulation - is that overkill?
thanks , Murray Mules
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: 1969 limo hood problem
« Reply #1 on: January 10, 2018, 02:12:34 AM »
G'day Murray,
The factory used a number of dabs of glue to stop the rattling, and it worked well.
As for using Dynamat, I would be inclined to use the original fibreglass mat that is held in place with a number of clips.   I purchased the matting from USA, and it was cut to fit, with the attaching holes in their correct places.
I wouldn't be surprised if when using Dynamat, it would suffer from gravity problems and fall off because of the heat from the engine itself.
« Reply #2 on: January 10, 2018, 04:26:12 AM »
thanks Bruce..... someone suggested liquid nails to use on the hood ... what you think?
will leave the dynamat out.... good advice
Murray
  • Administrator
      CLC Member #18992
« Reply #3 on: January 10, 2018, 04:36:46 AM »
Liquid Nails - ummmmmmm   Sounds like a good idea.   Shouldn't cause any rust problems like some silicones.
Offline V63
  • Name: W Link
« Reply #4 on: January 10, 2018, 05:40:15 AM »
Another thought: The added weight of the dyna mat might overcome the springs.
Offline Chuck Swanson
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #5 on: January 17, 2018, 10:11:18 PM »
Get some fusor from your body shop supply store.  I believe I used this, but would have to check (may have used fast drying-5 min)  https://www.autobodytoolmart.com/lord-fusor-metal-bonding-adhesive-medium-p-15934.aspx  Body shop suppy store told me what to use.
However, do it before you do the bodywork on the hood as you may pull it down a little.  Hang hood right side up when done.  Your hood will be solid when done...I did it on my 66.   Don't ask me why I know you should do it before you finish the bodywork on hood ;)  ...But it will save you an additional 20 hours of labor :)
Not sure on the liquid nails as it says nothing about metal on the site.  Chuck
« Last Edit: January 17, 2018, 10:19:54 PM by Chuck Swanson »
66 DeVille Convertible (3)
64 Series 62 (2)
64 2 door
66 Sedan DeVille hardtop
65 Eldorado Bk/Bk
69 DeVille vert
97 DeVille d'Elegance
67 Chevy II Nova (AACA GN 2016)
69 Dodge Coronet R/T
98 American Tradition 40' DP RV
AACA Lifetime
