Author Topic: help with identification and location of parts  (Read 98 times)
Online chris92026
  • Name: Christophe Perrin
« on: January 10, 2018, 11:41:09 AM »
can anyone tell me what is it for or where he goes
thank you
59 Cadillac Deville
C.Perrin
Online 35-709
      CLC Member #4719
  • Name: G. Newcombe
Re: help with identification and location of parts
« Reply #1 on: January 10, 2018, 12:19:05 PM »
The unshielded slide-on terminals indicate those wires are grounds.  The white plastic piece to the right of the picture looks to be a broken in-line fuse holder, so we might be talking add-on accessory, factory or aftermarket.  The small wire with the yellow connector should have that yellow connector replaced with an 18-22 red connector --- just asking for a broken wire there.  Sorry I can't be any more help than that.
« Last Edit: January 10, 2018, 12:21:11 PM by 35-709 »
1973 Cadillac Caribou - Sold
1950 Jaguar Mark V Saloon resto-mod
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #2 on: January 10, 2018, 12:34:33 PM »
If I had to make an educated guess - generator to voltage regulator harness.  This is one of the few locations where an in-line fuse was used.  The inline fuse was for the generator light in the dash.
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1977 Continental Town Car
Online 35-709
      CLC Member #4719
  • Name: G. Newcombe
« Reply #3 on: January 10, 2018, 12:41:53 PM »
Ah!  Good guess.
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #4 on: January 10, 2018, 04:15:41 PM »
Plus, the terminals definitely look like the ones used on a Generator and Voltage Regulator.
If this wiring is in a car that has an Alternator replacing the Generator, then these wires would have been removed, and the Alternator wired up in the normal way when bypassing the Voltage Regulator.
Online chris92026
« Reply #5 on: January 10, 2018, 06:26:16 PM »
thank you
will look at the diagram
still, a generator but everything has been a disconnect by the previous owner so more question to come  ;D
C.Perrin
