1955 Wheel Brake Cylinder compression fittings insert
Started by 55 ledsled, September 14, 2017, 02:31:25 PM
55 ledsled
Hello,
I bought some new brake cylinders for my 55 and had one hell of a time screwing in the brake lines. They wanted to go really far in...further than what my wrench could get a good grip on. Come to notice, I see that there might be some sort of cone compression fitting that should be in the hole like shown in my photo. Should the new cylinders come with these already inserted or can one buy some of these inserts and put them in the hole?
Thanks for your help!
Caddy Wizard
The new cylinders should either have these brass fittings pre-installed or the cast iron should be machined to replicate this.  But one way or another, they need the inverted flare surface for your flared brake line to seal against.  Otherwise, the line will never seal.
Art Gardner
1958 Eldo Seville (2/3 done)
Jeff Rosansky CLC #28373
I got all 4 from OPG and didn't have an issue. At least I don't think I do. Just tested in the garage. Hopefully I can test for real next weekend.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
