Author Topic: Changing the exterior color of my 67 Eldorado - my dilemma  (Read 1085 times)
Offline www.eldorado-seville.com
  • Gerald Loidl
  • Name: Gerald Loidl
« on: November 17, 2017, 11:42:29 AM »
Hi,
I'm currently restoring my 28k miles all original 1967 Eldorado.
The car still has its factory applied paint in Grecian white. Unfortunately the paint is too far gone to save it. The Eldorado is now at the bodyshop where it gets completely disassembled and striped to bare metal. All the original paint will be coming off completely.
Here is my car in the shop - short before disassembly started.
Atlantic Blue Firemist...
Originality has almost been the most important factor when I restored any of my cars in the past and until recently I would have never even considered a color change.
For me personally Grecian White is not exactly my favorite color and I think other colors fit the Eldorado better.
My Eldorado has a black interior so every exterior color was possible.
If I could go back to 1967 and order my brand new Eldorado, it would be one in "Atlantis Blue Firemist", like it was used in advertising.
Of course everybody has his/her favorite colors which cant be debated, and my rant here is more about to get your general thoughts about changing the color of a car and how much it hurts originality and the cars value, although I will never sell the car...
All work is done by one of the best restoration shops with no costs spared.
You can find a lot of pictures of the restoration here: http://www.eldorado-seville.com/files/67newpaint.php and here http://www.eldorado-seville.com/mycars/67eldo/restoration/
When cars are judged at the GN they do not get point deductions for color changes if it was a factory available color - is this correct?
Should I sacrifice some of the cars originality to get it in the color I like most? Or should I do everything to make it 100% correct again? (With a new paint job its no longer 100% correct anyways)
Thanks for your thoughts and input. I have a couple more weeks to decide which color it should get...
« Last Edit: November 17, 2017, 12:07:28 PM by www.eldorado-seville.com »
Gerald Loidl
1958 Cadillac Eldorado Seville
1966 Cadillac Coupe deVille
1967 Cadillac DeVille
1967 Cadillac Fleetwood Eldorado
1974 Cadillac Coupe deVille
1978 Cadillac Eldorado Biarritz
http://www.cadillac-bigmeet.com
Offline collector
  • Name: john rutenberg
Re: Changing the exterior color of a car - my dilemma
« Reply #1 on: November 17, 2017, 11:51:31 AM »
YES, change the color! If it's done well, you will never have any issues. I did it on two cars and could not have been happier. I did however paint them in single stage acrylic lacquer, so you couldn't tell if the car's had been repainted or not. I find most 2 stage paints to have more waves than the queen of England. I personally would never paint a car with a 2 stage process but you have to find an old school master, that knows how to paint with it. If done correctly, not even the judges at the CLC Grand Nationals will know. It's always worked for me! Good luck with you adventure.
Online Eric DeVirgilis CLC# 8621
    • CLC Member
      CLC Member #8621
  • Name: Eric DeVirgilis
Re: Changing the exterior color of my 67 Eldorado - my dilemma
« Reply #2 on: November 17, 2017, 12:36:55 PM »
As stated, no deduction will be made for any color originally available on any given model within any given model year.
Only item left to consider is if/when it comes time to sell, the color change will be a turn off to some buyers.
Being the car is a 28,000 miles example and if the interior is in high grade condition, this is an issue that should be pondered carefully.
Some of the areas where original paint which could have been preserved (such as under the decklid) would also need to be color changed and whatever originality that could have been preserved will be permanently lost.
If the project began with, for example, a well worn 100,000 mile car needing a full-blown restoration in & out, this would dramatically change the conversation.
A car with this kind of mileage - if well preserved otherwise - such a car is the last I would ever consider doing a color change to.
One man's opinion.
« Last Edit: November 18, 2017, 11:48:12 AM by Eric DeVirgilis CLC# 8621 »
A Cadillac Motorcar is a Possession for Which There is no Acceptable Substitute
Offline Scot Minesinger
    • CLC Member
      CLC Member #20543
« Reply #3 on: November 17, 2017, 06:42:09 PM »
Agree, change the color to what you want.
Offline 60eldo
  • EVERYDAY ABOVE GROUND IS A GOOD DAY
  • Name: Johnny.K. CLC MEMBER #27762
« Reply #4 on: November 17, 2017, 07:01:57 PM »
  White is georgious, DONT change the color,,,or spend 12,000 to change the color and loose 10,000 when you sell it
J. Kluczynski
Offline bcroe
    • CLC Member
      CLC Member #14630
« Reply #5 on: November 17, 2017, 07:05:08 PM »
A real beauty all right; not my color.  Well broken in means past 200,000
miles here.  But it may need a trans (and brakes, and tires, and timing
chain set) refresh to be a reliable driver.  And get a controller for that
switch pitch trans.  Bruce Roe
Offline savemy67
    • CLC Member
      CLC Member #29202
  • Name: Christopher Winter
« Reply #6 on: November 17, 2017, 07:13:50 PM »
Hello Gerald,
Your post includes three points that make me favor changing the color.
You state that: the original paint is too far gone to preserve, so originality is diminished once the paint is stripped; you will never sell the car, so resale value is not your top priority; you don't like Grecian White.
So what are you waiting for?
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
Offline J. Skelly
    • CLC Member
      CLC Member #15958
  • Name: Jim Skelly
« Reply #7 on: November 17, 2017, 08:53:58 PM »
I wish my Emperor Blue '68 (similar to Atlantic Blue Firemist) had paint half as presentable as what your '67 currently has.  If it were me, I'd look for an example in the color you want and sell this one to someone who appreciates it in white.  You might find one on the internet in a color combination you think you want, and that can help you decide before finalizing a color change.  However, when you go to sell it eventually when you get old or need money or lose interest, the color change will turn off some prospective buyers.  Mine has a white leather interior with blue dash and carpeting, and I really like the substantial contrast.  A guy I'm acquainted with had a '67 in Grecian Gold with white buckets and black vinyl top.  He really wanted a triple black car, and seriously considered repainting that car black.  I told him the contrasting exterior colors of the paint and top, with a contrasting interior, really made the car stand out.  Good luck with whatever you decide.
Jim Skelly, CLC #15958
1968 Eldorado
1977 Eldorado Biarritz
1971 Eldorado (RIP)
  • Gerald Loidl
« Reply #8 on: November 18, 2017, 11:37:05 AM »
Thank you all for your input! I can agree with everything said in this discussion.
I think I will honor the cars history and keep the original color.
Personally I would probably never buy a car where the color was changed during restoration and the value will be higher if the car still has the original color.
« Last Edit: November 18, 2017, 11:40:07 AM by www.eldorado-seville.com »
Gerald Loidl
    • CLC Member
      CLC Member #8621
« Reply #9 on: November 18, 2017, 11:42:35 AM »
A wise decision- and one that you will not regret.
Looking forward to seeing the final result.
I concur with 60eldo white is an attractive color for an Eldorado.
« Last Edit: November 18, 2017, 11:44:47 AM by Eric DeVirgilis CLC# 8621 »
Offline 76eldo
    • CLC Member
      CLC Member #22443
  • Name: Brian Rachlin
« Reply #10 on: November 18, 2017, 02:46:46 PM »
In CLC judging they do not look at paint codes on the data plate.
I'd stick with a proper Cadillac color and make the car the way you want it.
I'm in the same boat with a 66 Toronado. It's white with an excellent black deluxe interior.
It's going to need paint and I really like some of the other colors that Olds offered that year. When it gets painted it probably won't be white.
If you like 67/70 Eldos check out the thread on my 1970 I just got.
It's pretty nice.
CLC # 22443
I prefer email's not PM's   rachlin@comcast.net
1960 62 Series Convertible with factory Tri Power
1960 Eldorado Seville
1970 DeVille Convertible
1970 Eldorado
1976 Eldorado Convertible
1980 Eldorado Hess & Eisenhardt Convertible
1981 Eldorado Hess & Eisenhardt Convertible
1985 Eldorado ASC Biarritz Convertible
2007 DTS
2017 CT5
Offline gkhashem
    • CLC Member
      CLC Member #26576
  • Name: George K Hashem
« Reply #11 on: November 18, 2017, 05:15:31 PM »
Actually you answered the question properly all by yourself. I also would never buy a car with the color having been changed from the original color unless I got a very very good deal on a car in excellent condition. Here you have a low mileage car with an excellent original interior. All you are doing is decreasing the potential buyers and the demand for the car.
A color change would only decrease it's value. There are many cars that are very original low mileage cars with colors I am not crazy about. But if I do not hate the color I can learn to love the car. If I hate the color, I will pass and keep looking.
Life would be easy if we could find the car exactly as we dream. I am more than happy to find a great original and marvel at how the car survived in such a state.
You made the right choice.
1959 Cadillac Coupe Deville
1964 Oldsmobile 98 Town Sedan
1966 Cadillac Coupe Deville (Senior #861)
1970 GMC C/K 1500
1978 Cadillac Coupe Deville (Senior Crown #959)
1984 Oldsmobile Delta 88 Royal Brougham Coupe
1989 Buick Reatta
1991 Oldsmobile Toronado Trofeo (OCA 1st)
1991 Cadillac Eldorado Biarritz (Senior #838)
Offline Chuck Swanson
  • Administrator
    • CLC Member
      CLC Member #26619
  • Name: C. Swanson
« Reply #12 on: November 18, 2017, 06:30:04 PM »
Agree with George., Eric and other on orig color (I too generally avoid buying anything with color change).  They are plenty of '67s out there as I search all the time for anything 50s-73, so who knows, you may come across one in that color and buy it too, maybe a driver version with higher mileage :)  Chuck
66 DeVille Convertible (3)
64 Series 62 (2)
64 2 door
66 Sedan DeVille hardtop
65 Eldorado (vert w/bucket seats)
65 Eldorado Bk/Bk
69 DeVille vert
97 DeVille d'Elegance
67 Chevy II Nova (AACA GN 2016)
69 Dodge Coronet R/T
98 American Tradition 40' DP RV
AACA Lifetime
Like 65-66 Club: www.facebook.com/6566Cadillac
    • CLC Member
      CLC Member #20543
« Reply #13 on: November 19, 2017, 09:13:52 AM »
I do not agree that a color change diminishes the value on a 1967 Eldorado.  On a more expensive investor grade type of vehicle such as a 1959 Eldorado or V-16's of the 1930's this may be the case.  The 1967 Eldorado is awesome, but a frame off perfectly restored one is not in the price category where this would be a major issue.
The color of a perfectly restored car in the under $50k range (probably would not sell for more than that even it cost way more than that to restore it), is more important that it be appealing than original.
I would change the color to one you like, but of course a 1967 Eldorado color.
While keeping this car the original color is claimed to keep your options open by retaining more value via original resemblance, a good color will keep more options open.
Color of a car is very important, no matter the car and condition, it would be very unusual for me to ever buy a car with a color I did not like, unless I planned to repaint it.  One time in 1997 I bought a 1995 RWD Fleetwood with a vinyl top for a daily driver with the idea of removing the vinyl top, and it cost a lot to remove and re-paint, but Wow!, so glad I did.
Offline gkhashem
    • CLC Member
      CLC Member #26576
« Reply #14 on: November 19, 2017, 10:58:37 AM »
OK say you want to change the color.
How much would it cost and cost to do it right? I bet at least  $6,000 maybe up to $12,000. (Let's leave out Maaco and the do it yourself crowd)
Nothing looks worse than a poor cheap paint job. You get that and you will immediately lose 10K in car value. You think white has no curb appeal how about a poor paint job? Especially on a dark color. It sticks out like a sore thumb.
Door jambs, ends, sills, hinges, firewall, bottom of trunk lid. Remove all chrome, emblems, side markers lights, etc, etc.
Now keep in mind those in the group of leave it the same I think are thinking in the terms of an excellent, no rust, great interior, mechanically excellent, low mileage car. Not a total restoration candidate.
It defies logic to change it, but that's why we have vanilla and chocolate. Go for it and leave out about many potential future buyers.
1970 GMC C/K 1500
1989 Buick Reatta
Offline Roger Zimmermann
  • Switzerland
    • CLC Member
      CLC Member #21015
  • Name: Roger Zimmermann
« Reply #15 on: November 19, 2017, 11:20:24 AM »
As I changed the exterior colors from 2 cars, I cannot blame you if you do it. However, I would not paint a car dark blue with a black trim.
As it seems that you will keep the original color, my last remark may not apply anymore.
1956 Sedan de Ville (sold)
1957 Eldorado Brougham
1972 Coupe de Ville (not yet arrived)
CLCMRC benefactor #101
    • CLC Member
      CLC Member #20543
« Reply #16 on: November 19, 2017, 11:56:41 AM »
Whatever color you repaint it, get rid of the stainless steel door edge guards.  Those ruin the line of the car.  Look at the dark blue color in brochure and notice no door edge guards - part of the reason it looks great.
Certainly agree it has to be a great paint job, or no sense in even bothering otherwise.  Yes a color change does cost more.  That saying "the quality will be enjoyed long after the price is forgotten", certainly applies here.  You are not restoring this car to earn money, there are way easier ways to do that.
Blue with black trim was popular in late 1960's.  Look at the 1968 Fleetwood brochure, dark blue with black top.  This car does not have a vinyl top, so should be less of an issue.  It would be period correct, as opposed to say a black car with tan interior - which is more of thing now.
BTW a slick top is so cool.  The great lines and rocker moldings will make just about any high quality paint job color look great!
Enjoy your Cadillac!
Online D.Smith
  • 1961 Sedan deVille
    • CLC Member
      CLC Member #17592
  • Name: Dave Smith
« Reply #17 on: November 19, 2017, 01:30:09 PM »
Well said!    :)
Offline 59-in-pieces
    • CLC Member
      CLC Member #17326
  • Name: S. Butcher
« Reply #18 on: November 19, 2017, 02:42:27 PM »
Gerald,
I agree with Scott
As he wrote, "I do not agree that a color change diminishes the value on a 1967 Eldorado.  On a more expensive investor grade type of vehicle such as a 1959 Eldorado or V-16's of the 1930's this may be the case.  The 1967 Eldorado is awesome, but a frame off perfectly restored one is not in the price category where this would be a major issue."
Scott is so polite - NO ONE - in IMHO - would ask for, or expect a $10,000 reduction in price simply because the color of this car was not consistent with its Data Tag, at at the end of the day - you can say NO.
I personally like the deep blue with the Firemist metallic, as the color and sparkle sets off the lines and design of the body- way better than white.
I do collect 59 Eldo Biarritz - one is now painted Seminole Red, a Cadillac color of 59 but not an Eldorado color.  The other 2 are both currently Olympic White, an Eldo color, which I intend to change one to Gotham Gold and the other to Kensington Green (metallic) - each a Cadillac color of 59, but not an Eldorado color.
I strongly believe in MY enjoyment of the cars, and certainly do not worry about what others may think, now or later - as I or my sons will "never" sell the cars.
You have made up your mind, and it would be presumptuous to think that anything I may say should change your mind.
Since when should living your life with personal enjoyment be driven by a consensus of opinions from folks you don't even know.
Have fun,
Steve B.
S. Butcher
    • CLC Member
      CLC Member #8621
« Reply #19 on: November 19, 2017, 03:54:34 PM »
There are different ways of enjoying the old car hobby. For some, it may come from personalizing their car to individual preference; for others, it is the satisfaction of preserving all original aspects of the car to the best degree possible.
In life there are benefits and penalties associated with most any major course of action and those factors must be reconciled according to individual preferences/concerns/priorities- both long and short term. In order to make and informed decision, the contingencies should be known.
It would be a disservice to the OP to ignore the facts - pro or con.
« Last Edit: November 19, 2017, 04:09:08 PM by Eric DeVirgilis CLC# 8621 »
Get the CLCMRC 2018 Calendar - AVAILABLE NOW!
