WTB: Cadillac Trunk light mercury tilt switch
Started by Antti A, January 19, 2015, 02:39:34 PM
Antti A
Want to buy:
Cadillac trunk light mercury tilt switch. This small switch is located between the bulb and socket and it is originally carton covered. This is going to -59, but I think it is the same in many other yearmodels too.
I'm kind in a hurry with this issue so please make you offer fast!
Antti / garagefiftynineemail addresses not permitted
Antti Asunmaa - Industrial designer - Finland
http://garage59.blogspot.fi/
Martin Michaels
I've been trying to find them with no luck I have both out of my 47 but I can't get it to work still has mercury in it I did break one any idea why they stop working. Marty
Marty  CLC#26833
1947 6269  Cavern Green
1980 CDV D Elegance  White
Smedly
Can you post a picture of one? What would one be worth?
Sheldon Hay
russ austin
I have another mercury switch available.
email me at  russ85747@hotmail.com
R.Austin
Bobby B
#4
I have 3 broken ones in a box, so most likely not worth buying used. High probability that they are all old enough to be no good. They are reproduced……
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Jeffrey Burland
Here's Russ' picture resized.
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
Quote from: Martin Michaels on January 24, 2015, 01:15:22 AM
I wish I knew that too. I have 2 that were not working, took both apart and they both still have Mercury, I even put both lots of Mercury in one switch to see if the amount would make any difference and it did not, the Mercury was making good contact but would not pass electricity even when it was encompassing the contact point. Is there something about Mercury that is not conductible when its 70 years old?? Any metallurgists out there?
Bobby B
#7
Save yourself the frustration of a working/ non-working switch and a possible dead battery from it being constantly on.  They are available as a unit and you could probably retro-fit the internals into your housing for that "Original" look if necessary.  If you still want to rebuild your own, ebay and Amazon both sell mercury micro-switches only, that you could retro-fit to your housing for a few dollars. Hope this helps….
        Bobby
http://www.ebay.com/itm/Mobilistics-Mercury-Tilt-Switch-for-Alarms-Lights-etc-Hood-Trunk-Lid-Trigger-/201026378594?_trksid=p2054897.l4275
http://www.amazon.com/Parts-Express-Mercury-Tilt-Switch/dp/B0002ZPBKM/ref=cm_cr_pr_pb_t
Bob's Automobilia, pg. 97
1971 Datsun 240Z
1979 H-D FLH
russ austin
The stock mercury switches I have, are tested good pieces. I don't offer junk to anyone.
R.Austin
#9
Quote from: Bobby B on January 24, 2015, 06:11:37 PM
        Bobby
Dam, wish I had known that before I fitted a manual switch Bobby. :(
I see a lot of them now operate with a metel ball rather than Mercury.
TonyZappone #2624
I could not remember where I bought two of these a couple of year's ago.  It was from Bob's.  Seems like they were 20 something dollars apiece, and they worked well.
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
russ austin
Looked into the books, and 54-64 are the same.
R.Austin
Antti A
I made deal with Russ, hope it will come soon so I can try it.  ;)
6262
Hello Antti,
did you have problems to get the mercury switch into the European Union? I have read about a ban...
I need one also.
1962 Cadillac Series 62
1965 Pontiac Bonneville
gary griffin
It should be easy to conceal a modern switch in the wire where it is hidden in the cavity between the trunk lid and the inner sheet metal.
Gary Griffin
