WTB 1955 Steel Wheel Maybe '51-54?
Started by Joe G 12138, May 03, 2015, 07:56:32 PM
Joe G 12138
I'm in need of a plain old steel wheel for a '55. Supposedly '48 thru '55 interchange, but I need one where the valve stem lines up with one wheel stud hole. I'm in Wisconsin....  Joe Gibeault 12138
cadparts58
Joe,
I have two rims from a 53, but the valve stem hole is not directly across from the lug stud/nut hole. I can email you a picture if you like. I would have to send it to your email, as I can not resize on the forum. Asking $45 plus shipping. Thanx Frank
Frank Puma #10721
Joe G 12138
Thanks Frank for checking, but I just located and purchased a correct '55 rim.    Joe Gibeault 12138
