Author Topic: "Forever" Log-In Not Working  (Read 3423 times)
Offline Chris Conklin
      CLC Member #25055
  • Name: Chris Conklin
« on: February 24, 2012, 04:18:13 PM »
Since the recent refresh of the site I can no longer remain signed-in using the "Forever" selection. I have to re-enter my ID and PWord every time (and every time I select "forever" to no avail). This happens on my desktop machine and my iPhone. I haven't changed any settings on any of my equipment and the CLC cookie is still in place. Any advice?
Chris Conklin
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
Re: "Forever" Log-In Not Working
« Reply #1 on: February 24, 2012, 06:29:37 PM »
Chris,
Funny you open a topic on the same issues I posted a week or so back, it seems my previous message was removed.
I had to remove the main page from my favorites and save the forum page once I login to bypass the problem. Also I had to change the security level in my browser due to errors.
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #2 on: February 24, 2012, 07:29:26 PM »
G'day Chris,
Not sure what your computer is doing, but I still use the Forever Log-in.
I am using Firefox if that makes any difference.
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #3 on: February 24, 2012, 09:07:11 PM »
G'day Chris,
Bruce,
From the main page https://www.cadillaclasalleclub.org/ once you clicked the CLC Discussion Forums it takes you to https://cadillaclasalleclub.org/forum/ to login, once you login it takes you to https://www.cadillaclasalleclub.org/forum/index.php.
Before the changes once you enable the forever login option the link on the main page would take you to https://www.cadillaclasalleclub.org/forum/index.php else it directs you to https://www.cadillaclasalleclub.org/forum/ to login if you removed the previous cookies or the forever option was no chosen.
I have IE8 and IE9, hope this helps.
J. Gomez
CLC #23082
Offline Roger Zimmermann
  • Switzerland
      CLC Member #21015
  • Name: Roger Zimmermann
« Reply #4 on: February 25, 2012, 06:08:44 AM »
I have to do the procedure all the time too...Annoying.
1957 Eldorado Brougham
1972 Coupe de Ville (not yet arrived)
  • Administrator
      CLC Member #18992
« Reply #5 on: February 25, 2012, 06:56:53 AM »
I go straight to the Forum when opening up.
Offline PHIL WHYTE CLC 14192
      CLC Member #14192
« Reply #6 on: February 25, 2012, 05:33:45 PM »
I'm having the same problem,
Phil
Offline Bill Ingler #7799
      CLC Member #7799
« Reply #7 on: February 25, 2012, 05:40:24 PM »
Me too       BILL
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
« Reply #8 on: February 25, 2012, 10:58:08 PM »
Change your stored link to http://www.cadillaclasalleclub.org/forum/
It is the www in the link that takes you to the correct page.
I never have the problem and I use the link above.
Glen Houlton CLC #727
CLCMRC benefactor #104
  • Switzerland
      CLC Member #21015
« Reply #9 on: February 26, 2012, 02:27:00 AM »
Bingo! Thank you for the solution!
