Caddy parts mostly 50-60, some 70s
Started by Chuck Swanson, October 02, 2016, 11:39:00 PM
arch62
Thanks Chuck for hunting. The '62 - '63 cruise control started using a wheel. Other years are not usable.
Good luck at the show.
Dan LeBlanc
You are essentially looking for a one year only part that was prone to breakage. Almost always the gear in this setup is broken. I believe fellow CLC member Steven Tuck had the gear remade in some sort of metal for his car some time ago.
Dan LeBlanc
Eric DeVirgilis CLC# 8621
#22
For the E Brake of a 1959 Cadillac - do you have the silver J rod with threaded end in the center of the picture? May fit other years. Probably the same as 1960.
Also need passenger side Vent Control cable (no air conditioning car).
No "J" hook, but can't you buy a stainless J hook form Home depot, that looks the same.   Part of guy wire hold down kit.  Chuck
Ralph Messina CLC 4937
Hi Chuck,
I sent you a PM. Please check you mail.
Ralph
2018 GMC Yukon
Chuck Swanson
Only rear in teal and jade.  I have some more of these in a closed case-rear though.
CLC Lifetime
AACA Lifetime
Like 65-66 Club: www.facebook.com/6566Cadillac
66 DeVille Convertible-CLC Sr Wreath, (AACA 1st Jr 2021, Senior 2022, 1st GN 2022 Sr GN 2023), Audrain Concours '22 3rd in Class.
66 Sedan DeVille hdtp
66 Calais pillar sedan
66 Series 75 9-pass limo
65 Eldorado (vert w/bucket seats)
65 Fleetwood
07 DTS w/ Performance pkg.
67 Chevy II Nova (AACA Sr GN 2018)
69 Dodge Coronet R/T
Thanks Chuck. I thought of that but was concerned about the tensile strength. May go that route if no other option.
monibrian
Chuck....anything for a '68 deville.  Looking for trunk V emblem...upper bumper bar...trunk cadillac emblem cover...red seat belts for front....thanks for checking.
Chuck Swanson
Quote from: Eric DeVirgilis CLC# 8621 on September 25, 2017, 09:36:52 AM
Possibly the non-stainless version is stronger, but maybe a quick check with manufacturer as they are used for holding guy wires, so they may have some spec (ie close to grade 8 or not??)
CLC Lifetime
AACA Lifetime
65 Fleetwood
smatarese
Do you have the vertical bar and 3 bullets to the left of the gas filler door for a 59 Eldorado rear grill? I can post a photo tomorrow for clarity.
1959 Eldorado Biarritz
1960 Eldorado Brougham
Lexi
Will PM you regarding a generator. Clay/Lexi
Chuck Swanson
1960 grills and parts, but no '59.
I have 5 generator, and will check. Thanks!
CLC Lifetime
AACA Lifetime
65 Fleetwood
gmader
Chuck, do you happen to have any window frames for 1960 Series 62 convertible?  Really need the rear quarter window behind the driver.  Bought the car 15 years ago with a crack in the pivot corner of the frame (very common) and would finally like to get it fixed.  Hopefully with something that will last.
Lexi
BeavertonMike
Hi Chuck, do you have any body parts for a 62 Sedan de Ville? Or know of a parts car with a good body?
papas52cad
Hi chuck
I see here from last September that you had Sabre wheels available for sale, are these still available, i may be in need of one as I believe one of mine (a 55-56 vintage, pn 38612) may be bent.
I live in SAUGERTIES, NY so not all that far from you.
Looking forward to your reply.
Peter
1952 Fleetwood
CADEE
Chuck, I just came across your posting of 60's Caddy parts. By looking at some of your pictures, I think I see a box or two of floor mats that say "rear twin black" floor mats...#990987.
Do you still have them and...do you have a matching from set, in black? I would also take them in a bark blue, both front and back.
Thank you. Brad.
Brad.
1962 Series 62 Convertible.
1969 Fleetwood Brougham
Chuck Swanson
Yes, I have the Sabres.  I was looking to sell all 4 at once, but send me a message Peter.   I will be going through Saugerties on Fri or Sat and can deliver
CLC Lifetime
AACA Lifetime
65 Fleetwood
Chuck Swanson
Yes I still have those boxes.  I will confirm condition as I have not opened Brad.  You can send me a message.  Chuck
CLC Lifetime
AACA Lifetime
65 Fleetwood
chris92026
Looking for a wheel to use has spare
Front driver side lower bumper (to be painted )
66 Cadillac fleetwood
Thank you
Mike Baillargeon #15848
Chuck I need the rear quarter windows & the regulators for a 1955 Convertible.
Also I need a complete interior for a 55 convertible.
Thanks,    Mike
Baillargeon
#15848
