Author Topic: Crankshaft Hub Puller for Cadillac 500  (Read 637 times)
Offline Loveofclassics78
  • Name: D. Chatman
« on: August 24, 2017, 07:27:21 AM »
Good morning!  Does anyone have a custom made puller/installer or perhaps a used factory puller/installer to remove the crankshaft hub off a 500? I am looking to buy!  Thanks!
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Crankshaft Hub Puller for Cadillac 500
« Reply #1 on: August 24, 2017, 07:40:22 AM »
A normal puller will do the task, but make sure you don't damage the 9/16" UNF threaded hole in the centre of the crankshaft.
As for an Installer, I made my own using a long 9/16" UNF threaded rod, and with a nut wound up the thread, and a heavy duty washer between the nut and the hub, wound the hub back on.
Then I inserted a shorter 9/16" UNF bolt with a heavy duty washer into the crankshaft end to retain the hub tight, and to act as a means of manually turning the crankshaft in the future.
PS.   There is a piece of cork inserted in the thread by the factory when new, to protect the thread from rusting.
  • Name: D. Chatman
« Reply #2 on: August 24, 2017, 08:13:14 AM »
Thanks Bruce.  I was worried about using a normal remover.  I do have the bolt on order for installation.
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #3 on: August 24, 2017, 12:09:49 PM »
Yep, Bruce has it.
I just left my bolt in there to turn the crankshaft in the future. I put a little antisieze on it.
I think Scot Minesinger has a detailed post on how he did his with a threaded rod.
When done paint the rod the correct shade of blue before you put it on the shelf as you have just made a genuine Cadillac accessory tool.
CLC #28373
1970 Coupe DeVille
1955 Series 62
  • Name: D. Chatman
« Reply #5 on: September 23, 2017, 03:11:51 PM »
Thanks for the answers. I bought this threaded rod with the 9/16 UNF thread, but the rod was too big.  Did I buy the right one?
  • Administrator
      CLC Member #18992
« Reply #6 on: September 23, 2017, 06:17:38 PM »
From reading the label, you have the correct thread and pitch, so there is no reason, apart for the length as to why it won't thread in the hole.
You have removed the cork plug from the crankshaft?
  • Name: D. Chatman
« Reply #7 on: September 24, 2017, 12:43:08 AM »
Yes. Cork removed. There must be a specific diameter?
  • Administrator
      CLC Member #18992
« Reply #8 on: September 24, 2017, 02:36:29 AM »
All the ones I have here are 9/16" UNF.
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
« Reply #9 on: September 24, 2017, 03:00:00 AM »
According to my chart 9/16 18 is fine thread.  12 tpi would be course thread.
Maybe someone use the wrong tool and damaged the threads.
Glen Houlton CLC #727
CLCMRC benefactor #104
  • Name: D. Chatman
« Reply #10 on: September 24, 2017, 05:51:03 AM »
Well, it's not the threads that are presenting an issue, it's just that the rod is too large to fit into the hole where the threads are. Like I may need to try a 1/2 fine thread. Is it possible that some crank threads could be different?  That and keeping the crank from turning while removing the hub has become a PITA!
« Last Edit: September 24, 2017, 06:28:27 AM by Loveofclassics78 »
  • Administrator
      CLC Member #18992
« Reply #11 on: September 24, 2017, 07:00:21 AM »
I doubt it very much, as all the cranks would be machined to the same tolerances and measurements as every other 500 or 472 crank.
If there were differences, the factory would have two different pullers/installers for the same task.
There is the possibility that someone in the past used a puller to remove the flange without protecting the thread, and thereby distorting the end of the thread, thus stopping you from installing the correct thread.
Sounds like you need to obtain, or borrow, a 9/16" UNF tap and run it down the thread to clean it out.
« Last Edit: September 24, 2017, 07:23:02 AM by The Tassie Devil(le) »
  • Name: D. Chatman
« Reply #12 on: September 25, 2017, 10:18:37 AM »
Understood. I purchased a thread chaser/restored set (Lang 2581).  Going to run the 9/16-18 through the snout and clean up the threads. Hopefully, this will help. I will update soon!
  • Name: D. Chatman
« Reply #13 on: September 27, 2017, 09:15:52 AM »
Update:
The thread chaser is a no go, because there aren't any front threads to grab onto.  I'm going to try a 9/16-18 taper tap and see if I can get just a few threads on the shaft just to start the chaser.  Then do the rest with the chaser because I don't want to create new threads.  I hope this works.   If this doesn't work, looks like I may have to rethread the crank shaft, which is not bad to do, but I really don't want to.  Thanks everyone!
  • Name: D. Chatman
« Reply #14 on: September 27, 2017, 05:42:58 PM »
Fixed!  :D
  • Administrator
      CLC Member #18992
« Reply #15 on: September 27, 2017, 06:48:05 PM »
Great!
What was the actual problem?   A butchered thread?
  • Name: D. Chatman
« Reply #16 on: September 29, 2017, 06:19:00 AM »
Yes.  You guys called it.  The first few threads were gone due to a improper puller.  I used a 9/16 taper tap to start a few threads, then finished the rest with a chaser.  New bolt and rod are going in great.  My job continues on.
  • Administrator
      CLC Member #18992
« Reply #17 on: September 29, 2017, 07:39:21 AM »
Great news.
I hate it when someone uses the wrong tools and destroys something in the process.
Offline "Cadillac Kid" Greg Surfas 15364
      CLC Member #15364
« Reply #18 on: September 29, 2017, 11:37:10 AM »
I for one am glad I bit the bullet years ago and bought the Kent Moore J21052 tool (it is still available albeit some $560.00).  It makes pulling the hub or installing it a 2 or three minute job with no busted knuckles and not having to hold the motor from rotating.  For anyone anticipating doing this task more than 3 or 4 times in the future it would (IMHO) be money well spent.
  • Name: D. Chatman
« Reply #19 on: October 18, 2017, 11:29:10 AM »
I did see that tool. It is pricey for a one time job!
Question: When taking the hub off with the puller, how did you guys keep the
Crank from turning? I have a bolt inside the crank to protect the threads.
