Author Topic: How do I add an aux input to my 56?  (Read 346 times)
Offline gatech1956
  • Name: D Steeves
« on: September 29, 2017, 07:04:15 PM »
Title says it all. Looking to play some music from the era through my phone.
Offline Bobby B
  • Mendham, New Jersey
  • Name: Bob Bender
Re: How do I add an aux input to my 56?
« Reply #1 on: September 29, 2017, 08:22:55 PM »
They make all sorts of adaptors. Just Google it, or check out some good sites below. Good luck!
        Bobby
https://www.retromanufacturing.com
http://www.classiccarstereos.com
http://www.vintagecarradio.com
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Offline Chuck Swanson
  • Administrator
      CLC Member #26619
  • Name: C. Swanson
« Reply #2 on: September 29, 2017, 08:57:34 PM »
I had Robert rebuild two stock radios, one for my 65 and for my 66.  He added aux jacks.  Great job!
https://www.yelp.com/biz/precision-stereo-repair-marcy
Chuck
« Last Edit: September 29, 2017, 08:59:40 PM by Chuck Swanson »
66 DeVille Convertible (3)
64 Series 62 (2)
64 2 door
66 Sedan DeVille hardtop
65 Eldorado Bk/Bk
69 DeVille vert
67 Chevy II Nova (AACA GN 2016)
69 Dodge Coronet R/T
2010 Prius IV
2007 Ford 500 (2)
97 Dodge Ram 1500
98 Tradition 40' DP RV
AACA Lifetime
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #3 on: September 30, 2017, 07:43:25 AM »
I used a device called the RediRad. No need to remove the radio. Unplug the antenna lead from the radio. Plug in the lead from the RediRad into the antenna port. Plug the antenna into the RediRad. 12v positive and ground connections. Put it out of site. Run the cord. Be done with it. I've had mine for 4 years now with no issues. They have also improved them since then.
The way it works is that when it detects a signal from a device it disconnects the antenna and converts the signal from your phone to an AM signal into the radio. Tune the radio to the RediRad frequency and that's it. Installation takes about 15 minutes. Longer if beer is involved.
They have them for AM and FM. Positive and negative ground. I believe there's also a 6v version.
Mine is the AM version. Now that I have an am/FM car I may switch it out.
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1953 Series 62 Sedan (Parts Car)
1953 Fleetwood (Project Car)
2004 Deville
Offline Bob Kielar
  • CLC #25656
  • Keep Cruzin
  • Name: Bob Kielar
« Reply #4 on: September 30, 2017, 09:02:31 AM »
RediRad is the way to go.. Designed and built in Milwaukee Wi. Around $100.00 you can't beat it.
Keep Cruzin,
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
Offline MickeyCaddy
      CLC Member #29849
  • Name: M Chanslor
« Reply #5 on: September 30, 2017, 07:57:11 PM »
I have a RediRad in my '55 - I installed it easily myself, and I'm no expert wrencher. The rest of my Cadillac's radio/audio system is unrestored factory original except for the rear speaker.
An iPod Shuffle lives in the ashtray, and I set a pushbutton on the radio that jumps to the RediRad transmission frequency. The iPod/RediRad combo works flawlessly and is invisible.
The audio cable is long enough to pull out of the ashtray; it extends well onto the front seat, so you can plug in anything else with a mini-jack (1/8" stereo): a smartphone, a tablet, a CD player, etc.
I'm very satisfied!
Offline gatech1956
  • Name: D Steeves
« Reply #6 on: October 01, 2017, 10:59:23 AM »
Thanks guy! I was at a car show last month and a guy told me about redi rad but I couldn't remember the name until now.
Offline gatech1956
  • Name: D Steeves
« Reply #7 on: October 01, 2017, 12:04:41 PM »
I'm very satisfied!
I'm assuming you got the one that requires a negative ground electrical system?
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #8 on: October 01, 2017, 12:26:49 PM »
That's the one.
2004 Deville
Offline MickeyCaddy
      CLC Member #29849
  • Name: M Chanslor
« Reply #9 on: October 02, 2017, 01:46:02 AM »
Yes, the negative ground unit is correct for 1955. Easy to install; I tapped the "Radio" lead near the fuse panel for the hot wire (positive), and since the car's entire chassis is the ground, the RediRad's negative lead can be attatched to any nearby sheet metal screw.
That's why all the light bulbs only have a one-wire connection: the entire chassis is the negative terminal. Same goes for the rear speaker - only one wire.
On the 1955 models, anyway...they sure did things differently back then!
Offline gatech1956
  • Name: D Steeves
« Reply #10 on: October 07, 2017, 01:14:10 PM »
So I ran into small problem. Got it hooked up and everything and got my phone to play music through the speakers. But it won't cutover to normal am when I unplug my phone
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #11 on: October 07, 2017, 02:22:32 PM »
How long did you wait after unplugging?  May be a defective unit?  Mine sometimes takes a few seconds. That's so that the unit doesn't inadvertently cut out while playing a low volume part of a sing
2004 Deville
Offline gatech1956
  • Name: D Steeves
« Reply #12 on: October 07, 2017, 02:55:09 PM »
well I unplugged and plugged in the antenna cords and did the classic turn it off and on again and starting getting AM again. What's weird is that when i stuffed away the aux cord back in the glove box the AM frequency came back faster. The AM goes away when I start fumbling with the aux cord. Guess it just takes a few minutes for it switch over from the AM signal to the phone or vice versa. Otherwise, nice product. It's cool hearing Dean Martin or Sinatra through an old AM radio like that. My car is practically a time machine now.
