Author Topic: 1936 3 window LaSalle Coupe  (Read 131 times)
Offline FCZ
      CLC Member #20882
  • Name: Frank Zumpfe
« on: October 02, 2017, 10:56:09 AM »
I have a '36 50 8 cylinder in-line engine for my LaSalle. Parts needed are:
1.fan and pulley for water pump (pulley has a hole for lubricating the water pump)
2.front motor support for in- line engine
3.for the distributor I need a shaft that goes from distributor to the oil pump
Could I get any specs for the shaft that is missing from the distributor to the oil pump?  Are there any drawings of the shaft with dimensions that someone could possibly send me?
Thank you,
Frank Zumpfe
